New WoodChat!
Poison Ivy
Poison Ivy
Poison Ivy
TomD
I thought there might be someone here who knows about urushi(ol). Given it is present in Japanese lacquer, and there is some depth of Japanese craft exposure here, I was wondering if anyone knows anything about a material to remove it from skin, post bond. I have minor sensitivity and fairly major potential for exposure on my farm. I have had good success with Tecnu, other than getting it up here. Though I now know of at least one expensive source. Still wondering if there is some overlooked solution out there. The gougeons had a home remedy for cleansing epoxy, and it works better than any of the commercial products I had tried, so something simple that worked better than various laundry soaps would be fun.
I thought this was an intresting discussion of the Ivy oil:
http://www.newton.dep.anl.gov/askasci/chem03/chem03357.htm
Re: Poison Ivy
David Barnett
(Message Deleted by Poster)
Re: Poison Ivy
Jack Guzman from Maine
Sweetfern
Comptonia peregrina (Sweet fern)
I have always been sensitive to poison ivy. As a kid I got some pretty extensive rashes.Calamine doesn't help much. When I met my wife she kept a large jar of brown liquid under her sink that said "don't drink" on it. She called it poison ivy potion. It consists of a tea made by boiling the leaves of a local fern.
I tried it on a budding rash for the first time and the rash just dried up and went away. I've used it since for years and passed it on to others.
I have no idea how or why it works but it does. If you don't have any near you email me,I will gladly send you a sample. It grows along side the roads here.---Jack
Re: Poison Ivy
David Barnett
Now THAT is interesting, Jack.
Re: Poison Ivy
Alternative to Tecnu
Bill Tindall
The stuff that causes the rash is "oily". To remove it from skin takes something that will remove oil from the skin, a problem mechanics face every day.
Tecnu is simply an emulsion of deoderized kerosene. It was designed to be a waterless cleaner. Gojo is equivalent for the purposes of solubilizing the poison ivy juice. I have found the better smelling Fast Orange to be less so. The bottom line is that anything that will effectively remove grease and oil will remove poison ivy juice that hasn't reacted with cells. Once that happens the result is irreversible.
Another possibility I have not evaluated is some sort of bleach. The molecule that causes poison ivy has a greasy end and an end that reacts with your cells. This reactive end should be easily destroyed with a typical bleach. But again, I have not tried this approach.
The way this nasty stuff works is that the oily end enables the molecule to be transported through the skin barrier. The reactive end fastens to a cell. The immune system detects a "foreign" cell and kills it. The immune system can become over activated and start causing havoc. (or so it was explained by biologist of some sort that I once met) I am extremely sensitized to poison ivy as a result of repeated exposure and a misapplication of steroids that screwed up my response to it.
Re: Poison Ivy
Couple things
Where we live, poison ivy is rampant, swallowing up entire trees. But, as often in nature, the traditional antidote is often found nearby. Here in PA, that antidote is jewelweed, Impatiens biflora. Just squish up some of the succulent stems and apply directly to the affected area.
On another note, I was very susceptible to poison ivy sufferer as a kid, but my pediatrician gave me a series of injections that were supposed to provide some sort of immunity to the effects of poison ivy. Around the same time, I also took daily doses of an over-the-counter drug called Antivy that I believe included pulverized dried poison ivy leaves. One or the other worked though, and I've been virtually immune to poison ivy ever since, over 50 years.
Re: Poison Ivy
David Barnett
Re: Poison Ivy
the origin of Tecnu
Bill Tindall
This stuff was developed under government contract as a waterless hand cleaner. To emulsify a hydrocarbon (kerosene/mineral spirits/etc) one needs a surfactant. Tecnu has a surfactant that accomplishes this task and so does every other hand cleaner based on an emuslion of a hydrocarbon solvent.
To get the poison ivy juice off the skin, or possibly extracted from the outer layer of skin, requires a good solvent for the urushiol, which is a mixture of oily allergenic compounds. Additionally, this good solvent must remain in contact with the skin for some time to allow for solubiliztion and perhaps extraction. Then the hydrocarbon must be easily washed off the skin taking the urushiol with it. The process is no more complicated than that.
Both the hydrocarbon and the surfactant will be good solvents for the urushiol compounds. So is toluene and alcohol and a bunch of other stuff, all of which will evaporate too quick to be best at removing the urushiol. I don't know if one surfactant would be somewhat better. However, the sea of hydrocarbon will be the main extraction solvent I would predict.
I would expect pure surfactant to work just fine, but it would be very costly to offer as a consumer product and it could cause 0.000001% of the population some problem if not used properly.
The linonene in Fast Orange will be an excellent solvent but this expensive solvent may not be present in high concentration in Fast Orange. I don't find that fast orange is as effective as stinky Gojo at removing "car fixing grease" so it is a reasonable assumption that it will not be as effective at removing urushiol.
The bottom line for me is that anything that removes old car grease is going to be effective.
If you want to try more concentrated surfactant then go to the Ag store and buy surfactant concentrate for emulsifying Ag sprays. A gallon will only be few bucks. Personally, I'm sticking with Gojo.
Re: Poison Ivy
Re: I can see that the main ingredient in Tecnu is
TomD
I don't like pumice. And for poison ivy I don`t think it sounds all that wise. Some of the first aid stuff specifically recommends against reducing skin integrity.
I find Tecnu is very effective even well after the bonding, it may not affect the bonded layer, but that layer might also be overlaid with a lot of unbonded stuff. I find the dispersal effect somewhat odd. I am reliably allergic to the stuff, but not very quickly. So the stuff sits on me while I think I have a bad mosquito bite, etc... Eventually I realize I have been exposed. I get some stuff and slap it on. The odd bit is there is normally a pattern of further contamination. This time a mild rash on an eyelid, etc... But they are quite locallized, the offending finger has a localized patch. One would think that if the stuff remains active for so long, a minor amount can trigger, that the distribution would be wider, and the contamination a lot worse.
Re: Poison Ivy
clarification
Bill Tindall
"improve the urushiol-neutralizing effect". The mode of action is solubilization and extraction.
It should be possible to neutralize, implying some chemical process, the urushiol by oxidizing the end of the molecule that reacts with the cells with some sort of bleach. But I have never heard of anyone exploring this possibility.
Again, I find Gojo works fine if applied soon after exposure. It is more irritating around the eyes but I can put up with that shortcoming when I consider cost and availability.
Re: Poison Ivy
Bill Tindall
I would not recommend waterless hand cleaner with any abrasive for the reasons you stated.
If your immune system gets screwed up either by sensitization or use of steroids then exposure on the hand can trigger breakout on some place that was affected years ago. In my case hand exposure will cause a rash to develop here and there all over my body.
In my case it takes 24-48 hours to develop symptoms and now days recovery has been lengthened from 1 week to two.
Re: Poison Ivy
TomD
http://waynesword.palomar.edu/ww0802.htm
Interesting stuff there. As usual, vitamin C to the rescue.
And this to say on Tecnu:
A product called Tecnu Oak-n-Ivy® Cleanser is now marketed through forestry supply catalogs. It contains a mixture of organic solvents and wood pulp by-products which remove terpene resins and urushiol from the skin. Thorough rinsing with water is recommended. Other organic solvents, such as rubbing alcohol, would probably also remove the urushiol residue. Of course, if the allergen has already penetrated the epidermal layer and bonded to deeper skin cells it is too late. Interestingly enough, the original Tecnu product was developed to remove radioactive fallout dust from the skin without water (Mermon, 1987). It was supposed to be stocked in fallout shelters across the United States. Later it was found to be highly effective in removing paint resins and, quite by accident, urushiol. [Tecnu is a crude distillate of gasoline and is quite expensive compared to other solvents such as gasoline, paint thinner and acetone.] Another product that claims to remove urushiol from the skin, even after a rash has developed, is called Zanfel™. Check the Zanfel web site for more information.
Re: Poison Ivy
Re: clarification
TomD
There is mention of oxidization, Bill, in that Wayne`s World article. They recommend some interesting alternatives to bleach.
Re: Poison Ivy
Waynesword
Bill Tindall
Well, that is as much as anyone will likely ever need to know about the topic!
I like the idea of the enzymes that destroy it.
A sufficient dose of steroids will knock out the symptoms almost immediately, but there may be a price to pay later.
Re: Poison Ivy
Re: Poison Ivy
TomD
Just an update. Jewel weed lowered the swelling and eliminated the itch, notwithstanding some skepticism in scientific circles. Not as effective as my steroid, but I guess the skin will eventually stop acting up, and so long as it isn't bothering me, it doesn't cost anything, or do any harm. I'm pretty sure I got the pox from the cat.
