We value your privacy.
What was commonly used in the 18th century for measuring in the shop? I'm curious about both small (1inch or less) and longer (1 foot and longer). I can see using chisels and irons for a lot of measurement but were rulers with 1/8 and1/16 marks common?
Well, they didn't call it a "rule joint" (ref. Aug. 2012 issue of Popular Woodworking for more on the rule joint) for nothing. Rule joints have been incorporated in table tops since at least the 18th Century.
The Hay Cabinet Shop at Colonial Williamsburg uses reproduction 2 foot single fold rules that are period correct for mid-18th Century colonial America.
The inventory of the 1797 Tool Chest of Benjamin Seaton lists a rule, which is now missing, so we don't know any details of its design.
Jane illustrates several rules in this book from the 17th Century. One illustrated 18th Century rule is graduated in 8ths. Two older slide rules have logarithmic graduations much finer than that. One of these, which would have used dividers instead of a slide for multiplication and division, is from 1623. She also notes a rule created pre-1545, recovered from the Mary Rose, and documented by Richard Knight in the journal Tools & Trades.
(And, yes, I use a slide rule in my shop in addition to a four-fold box & brass rule, but they are much newer than these references.)
To quote Henry Mercer, 'In the seventeenth century, a flat, home-made straight-edged wooden strip, either one or two feet long, scaled in inches, halves, quarters and eights.'
A quick check of the Internet revealed that two fold rules can be dated back to the early 17th century. The American manufacture of rules begins about 1800. It would seem to me that a dividing engine would have much in common with a clock. Boxwood rules were more accurate than ivory rules because of boxwood's lack of expansion and contraction due to humidity. Both were hand made. A skilled rule maker could mark a rule in about 10 minutes. I would think that for an 18th century American woodworker, a rule would be yet another expensive imported tool. I would imagine they owned as few as necessary working without them if possible.
If you start with a known measure, like a foot or a yard, it is pretty easy to make a rule. Using dividers just now, I divided a foot into inches and one inch into eighths in five minutes or so.
Are you sure it was marked in Imperial inches? It's more likely that it was marked in French inches. Of course, those weren't the only choices. There were also Paris inches, Gamla inches, Nya inches, Spanish inches, Russian inches, Riga inches, Amsterdam inches, Groningen inches, Danish inches, German inches, Rhynland inches and many others. Philip E. Stanley's Source Book for Rule Collectors provides a comprehensive list of inches, with conversion factors.
You all have inspired me to try and make a rule and maybe even a two fold. The gripe I have with rules available today is that they are too good. What I mean is that I don't need 32nds or even 16ths. Measuring down to an eighth is usually all I need and sometimes a sixteenth. Anything finer is just a distraction.
David, I'm going to cheat (when I finally get around to it). I have a Sherline lathe and mill. I also have a four fold I bought from Garret Wade a while back to copy the joint. The fold out joints, not the main joint, look to be the hardest to do right. They appear to be a hinge with fingers rather than leaves. That's why I'll probably make a two fold. Of course this project will be put into line behind the others. I'm going to go into tool-making mode here soon and try to produce a number of things.
