New WoodChat!
test
Re: test
Re: test
eliot d
Is there an image here? Is it working?
Re: test
Re: test
There appear to be two pictures there, Eliot - the same still life (chisels with wood), with slightly different exposures.
Re: test
Re: test
eliot d
Yes, there are two of the same because I barely know what I'm doing. I'm going to try to send more; I've got the dai done including having cut the abutments and beginning to fit the iron. I'm going at an INCREDIBLY slow pace. What happened is that, despite careful measurements, the abutment "slot" is kind of narrow. Now that is not actually a fatal flaw because , as you all know, the bevel side of the Japanese iron is hollow; so to get a perfect fit, I have to widen the abutments anyhow. What is saving me is the so-called "blunt chisel" technique that I learned here. Watching me, one would think that I was filing the bed; but I'm not: it only looks that way. I have to get some dry eraser marker now to "see" better where to remove wood for fitting the iron all the way. (All this work and it's only a practice piece using( I think) tulip wood!) I suppose there's nothing wrong with it except that it's kind of stringy. I don't have problems across the grain, but not so good with the grain-- little splinters, etc. I do have two really nice, imported, blocks of Japanese oak that I have squared up and will work on later after I (hopefully) finish this piece. I can tell those who haven't tried this and are thinking about it that you're in for it!
Re: test
Re: test
Brian Anderson Gunsmith
I see two pix as others have said.
Both of the same objects; several chisels and a Japanese plane body.
As for the need for dry markers, in gunsmithing school we were taught a technique called smoke fitting.
Where we would burn an oil lamp that produced a thick sooty smoke.
The piece of metal being fitted would be passed through the smoke.
The metal part would be inserted where it needed to be and the soot would rub off on the objects that need to be filed.
Re: test
David Barnett
(Message Deleted by Poster)
Re: test
Re: Works great...
eliot d
Do you or Brian worry about using this technique. which does involve flame and heat, with very fine tools. e.g. an expensive Japanese iron? What's wrong with cooler methods?
Re: test
David Barnett
Re: test
Re: Smoke 'em if you got 'em
eliot d
I'll try the soot just to see how it works. Thanks.
Re: test
Re: Works great...
The technique known as "smoking a fit" or "smoke fitting" is used when fitting two pieces of metal together.
It might also be used to wood from metal.
First a basic attempt is made to get the pieces involved to be near the right simple shape.
Then a part that is to be fitted is smoked. The smoke is no where near hot enough to hurt the metal.
It merely coats the metal with soot. The part is metal.
When the two parts are put together the smoke rubs off of one piece onto the other part.
In the end this normally leaves both parts knowing where the other one made contact.
Unfortunately we normally are only changing the shape of one of the parts to fit.
But it often educates us on where the fit will cause the shape to change.
Again allowing us to make basic simple shape changes.
The changes are generally made with only a file.
No power tools need apply.
We want to sneak up on a good fit.
Not overrun it.
I learned this technique in gunsmithing school.
It was used entirely with metal parts.
Those parts still needed to be polished and finished.
Good thing about the use of soot is that it has not real intent to stay on the metal.
Unlike some markers that are intended to be non-removable. But are partially.
Re: test
David Barnett
Re: test
If you like...
John in NM
You can similarly use a light paste of lamp black and thick oil or thinned grease, or a tube of artist's oil paint. If locating either of those is too much trouble, you can crush a high quality charcoal briquette and mix it with the oil or grease. Just try to crush as finely as possible, a rolling pin would work great, but you'd probably get hit with it if she caught you :D
Re: test
Re: Used to be little oil lamps...
That is the one I was talking about.
