New WoodChat!
Some more on abrasion(flatening)
Bill Tindall
More from the notes I took from the tribology book:
There are two kinds of abrasion, two body and three body. In Two body abrasion the grit is fixed and it moves over surface being abraded- cast iron diamond plate, sand paper, stone. In three body the grit is located between a hard surface and the surface being abraded- some recommended flattening procedures are three body arrangements. In fact some companies sold grits and a glass or steel plate for this kind of abrasion.
The book says that three body abrasion is about TEN times slower and it leaves a different finish (lumpy).
Re: Some more on abrasion(flatening)
Hmm
Does this mean that it is faster and more accurate to flatten a plane sole with a two-body method?
Leo Cuellar
With diamond now being the favored 3rd body
Leo Cuellar
isn't that an outdated model as David's link suggests? Is there a discernible difference between how effectively diamond cuts being bonded to a surface VS being applied in an oil or paste? Found a nice old tablesaw top to cut up for plates... now I wonder, should I buy film bonded or loose diamonds?
David Barnett
(Message Deleted by Poster)
Diamo9nd on cast iron is two body abrasion.
Bill Tindall
That is why cast iron is recommended, Diamonds embed in it and stay put, unless the grit size is too large. In that case use Plexiglas.
Leo Cuellar
Re: I'd still go with loose or paste...
Leo Cuellar
Thank you for the input, David. I have to do a search on more of your posts concerning diamond. That project is still a ways off, but that was pretty much what I had planned on anyway, considering the input from what most folks have said about it. Mostly was just having a little fun as my nailspinner is in being serviced. :D Spent a couple of hours out in the sun working over a rescued railroad iron anvil, somebody had a vision for it once, just about got the top ready to be polished. Trying to make the most of the few sunny days we've had up here, have to go back to work on Monday.
