Frog trouble...
Edward in Vancouver
There was something weird about the guy at the flea market, had a table of junk but one #7 that looked promising. He wanted $100 for the #7, and I was stupid enough to ask why. I pointed out that it was nothing special, a plain jane Stanley, decent enough shape, but not a Bailey, nor a Bedrock.
Fair enough, he says, $10 for the plane, $90 for the blade and chip breaker. I have a #6 at home and a LV replacement 2 3/8" blade, so I gives him the $10 and takes it home.
And that's when the trouble started....
The #6 blade assembly engaged OK, but I couldn't get it to peek out of the sole. After fiddling and cursing, I realized the frog was jammed all the way to the end of it's slots, but the edge of the frog was a good 1/8" away from the mouth. After taking off the frog, something wasn't right, but I didn't know quite what it was. I stuck a square against the the leading edge of the frog, not square... matter of fact the edge was kind of rounded, and there were grinding marks on the bottom of the frog.
Compared to the mouth on my #6, the mouth on the 7 is a good 1/16 wider, but at least it is filed square
I could file the screw holes deeper to get the frog closer to the mouth, but even so, I don't think I could get enough iron to peek out of the mouth.
So, I'm hooped, and have two burning questions...
1) where can I get a used frog?
2) Why would someone modify the frog? I don't think it was to modify the angle, the bottom of the frog was filed a bit, but not a lot. Why modify the frog on a 7? A 4 or 5, I could understand, but a 7? But even so, if you remove a good 1/4" of frog material, the edge should have a blunt edge to it, this one came to a point, and it doesn't look like the bedding surface was filed, just the bottom of the frog.
What was the reason for the modification?
