fettled a really old #2
bridger
...that I inherited from my grandfather. lapped the sole, stoned the mating faces between the frog and base castings, lapped the top of the frog. relieved the top front of the mouth away from the frog a bit with a file. sharpened the blade with something on the order of .020 crown, stropped that 'till it shaved cleanly, fitted the chipbreaker so no light gets through, set it really close to the edge. adjusted the frog forward till just a tight gap remained. the old #2 planes never had a frog adjusting screw, and nothing holding alignment between the frog and base- makes for a lot of trial and error to get the mouth close and parallel.
on a piece of nasty, curly, crotch grain hard maple it leaves a glowing smooth surface with no hint of tear out.
Bridger
