mass is probably the more important factor
Ian in Sydney
I am working on a couple of BU shoot board planes and with the recent discussion of zero/5º clearance angles, I'm wondering what a practical clearance angle could be? My current plan is 13º as that seems to be the lowest in common use (Philly & Brese may be as low as 8º, depending on bevel angle (BD)).
I've used a LN#9 (BU, so the bedding angle of 20° equals the clearance angle), a #5 and a #6 (all BD with a 45° cutting angle and 25° primary bevel with an approx 5° secondary bevel) all work well with a shoot board BUT across that range, it's obvious the more mass the plane has the better it works.
I suggest the clearance angle is not critical -- 25° might be the practical minimum for a BU woody -- but how to add more mass is
