New WoodChat!
OT How would I prepare...
Stephen Shepherd
Stephen Shepherd
commercial peat moss to use it as a fuel?
Stephen
Re: OT How would I prepare...
Re: Do you mean...
david weaver
... to use it like the irish cut peat, let it dry, and then burn it?
I wonder if you could even do it.
Seems like the process would be relatively simple to replicate the more dense peat that the irish dig - you'd have to find some way to make it wet, apply pressure to compact it and then let it dry.
But that would be a lot of work, and expensive at the same time.
TomD
It isn't really a moss in Ireland, it comes out of the ground as "turf' which is a black brown brick of mud that is cut by a special spade. They cut it out by hand and lay the bricks aside to dry. Once they have dried they burn somewhere between the energy density of wood and coal, I would say observationally.
There are commercial mining operations that harvest it for either sale to houses or power plants. When I lived there, there was a compressed product that we burned that looked like interlocking brick. It came in bundles with banding, and was burned more or less like regular turf, it would separate out in layers as it burned.
There are places in canada where they harvest it commercially but I have never seen what it comes out like. In Ireland, back before they got rich, driving anywhere in the country you would see peat, or people out cutting it, the way you see piles of wood at houses in the north woods. With the exception that the ground is wide ope without trees in places, and one can see a lot further.
Where I come from is touted as... *LINK*
Denis Chenard in Ottawa
...the "peat moss capital of the world": Rivière-du-Loup, Qc.
Or at least that's what's claimed around here... In any case this is an active industry in these parts (I'm visiting my parents, who still live there).
When I was a kid there were bogs in production less than half a mile from home. This was grueling work: in the scorching heat (even in that climate), infested with mosquitoes, workers were "extracting" slabs of peat by digging trenches using spades. Keep in mind that the bogs were not 100% sphagnum, lots of twigs and branches buried in there. So the workers needed REALLY sharp spades to cut through all this. Tough too. And corrosion resistant (bogs are acidic). Probably makes keeping woodworking tool edges sharp a piece of cake ;)
Abandoned bogs lived a second life as blueberry patches, they just grew naturally there (acidic soil?). Only thing to remember is that the blueberry bushes tended to cover the previously digged trenches... Real heartbreaker to forget that at the end of the day and lose all your efforts down the trench (DAMHIKT).
As for use as fuel, it wasn't done in my neck of the woods (too much lumber around here). Based on the information in the link below, Finland is by far the largest consumer of peat for energy purposes, almost twice as much as Ireland.
As for your original question, Truly dry peat moss bagged in "bales" (at least the way it is produced here) is too dry to compress IMHO. The stuff is shipped bone dry because sphagnum can absorb up to 20 times its weight in water, and producers don't want to ship product at 20 times the cost... Maybe you could spritz it a bit with water to see if you can compress it so it holds its shape? Just guessing here. I think that, if you want to make peat moss "pellets", "bricks" or "pucks" (pick your shape) you would need some kind of hydraulic equipment.
Maybe you could use some kind of oil instead of water? I guess some would be safer than others...
DC
http://www.peatmoss.com/index.php
Gary Roberts
You might want to start here:
http://www.peatsociety.org/
Apparently everything has a society to represent it.
Gary
