Source: unique 7" spiral scroll/coping saw blades?
Bert Bleckwenn
I have inherited an old scroll/coping saw with a 7" spiral blade that I am having difficulty find replacement blades. The saw is just a 1/4" steel rod shaped into a copIng saw profile and has two slits at each end to insert blades in either a vertical or horizontal position. The saw has enough spring to tightly hold the blade.
The blade is somewhat unique in that it has 1/4" flat section near each end and, a sharp bend after the flat sections, and then returns to a round section so it is held in place in the saw frame slots.
All the spiral scroll saw blades that I have found are 5". A standard 7" coping saw blade with pins will fit, but I'd like to find the same style of replacement blade.
Anyone know of a source for these 7" spiral blades with flats and bent end?
This was likely more of a hobbyist tool, but I'm assembling a set of tools for my grand kids and am trying to use as many of my ancestor's tools as possible.
