A "refill" plane
craigd
Tom asked for "a few words and images about your plane", which I'm happy to do.
I call this a "refill" plane because the "infill" is on the outside and the metal is on the inside. The body was carved from a solid chunk of Pear and just gives my hands a way to move the blade. The guts are mild steel and a movable frog of Aluminum (which works really well a frog material because it doesn't "ring" and is "sticky" so the blade wants to stay in position).
The blade is 2" x 1/4" D2 but the mouth slot is only 1/8" so the blade can't fall out and is bedded at 50º.
The lever cap was carved from 1/2" steel plate and the screw was turned from brass rod.
