New WoodChat!
Desperately in need of a chipbreaker
Mark Hennebury
http://www.wimp.com/cuttingsteel/
Re: Desperately in need of a chipbreaker
David Barnett
Thanks for the video und Die Zauberflöte, too.
bitte
craigd
craigd
Thanks, that was really interesting, I had forgotten that a lot of my metal tooling has formed chip breakers (ie the carbide insert has an integral chip breaking shape) and they are called chip breakers.
Mark Hennebury
It was quite fascinating to watch, and very similar to cutting wood, albeit without the weakness of the "against the grain' separating of wood fibers. It was quite surprising how little cutting the tip was doing at that magnification and how much plowing seemed to be taking place.
The carbide inserts have used the integral chipbreakers for quite some time, i really don't know how long but would be interesting to check and see.
craigd
craigd
I did notice that there was "tear out" when a blob of steel would get stuck on the tip of the cutting iron. And that the lubricity of the TiN coating really helped (the real stuff isn't just gold paint).
I think chip breakers predate inserts so they have been around for quite some time but are still undergoing rapid development. The ones I can't wrap my head around have a negative rake (planes cut with a positive rake).
bridger
bridger
think scrapers.
craigd
craigd
think scrapers.
As in card scrapers with a burr? Hmmm, I guess that means it has to cut with a negative rake to get around the rounded over end of the scraper or the cutting edge wouldn't engage the wood. Thanks!
craigd
I recant!
craigd
I thought about this some more and came to a different conclusion: a scraper with no burr will have zero to negative rake, while a scraper with a burr will have a positive rake when you tilt it while scraping. My mental model is a upside down "T" with the wings of the T being the burr.
bridger
Re: I recant!
bridger
yep. that burr is pretty similar to a plane blade set up with a close set cap iron.
but a nice sharp card scraper just honed square with no burr will also cut wood cleanly, if a bit less aggressively.
