We value your privacy.
Managed to able down to the basement without falling down and even got back up. In between, I managed to rip down the second side to my simple box. I took my little kanna to it and now have to square, even, 6 side planed sides to a box. May not sound like much but to me it was a big step
Now let's get out the brad nailer, some pocket screws and a couple of other odds and ends of the solve all metal fastener category and let's wrap this thing up!
Well, went down and tried another end. I was a little rough on the process and somehow got one side off so when I 'leveled' it it's a little shorter than the sides. I'll do the other end the same height and then decide it I want to work down the sides or figure the difference into the top design.
Making small boxes is harder than it looks. A better beginner project is actually something a little larger - maybe a Shaker wall cabinet or something along those lines.
As a newby, IMO, you'd be better off not using stock less than 3/4" thick and also not trying to cut joinery on small workpieces. You need something scaled for your hands -boards at least 18" long and the aforementioned 3/4" thick.
Of course, you'll probably now complete a box that would make Doug Stowe envious.
...is what I ended up with. Thought I did pretty well with the end of the box I did yesterday. Went down to try the other end this afternoon. Cut it to a little oversize and discovered that I have a talent for ripping large arcs.
Decided to use the other side of the board that I cut since my arc was into my 'keep' piece this time. Went to get it square on the non-humpback side and - ended up with a banana. So I know that I'm supposed to apply more pressure on the middle of the board - front hand - even - back hand through the board. Lesson learned maybe.
Went back to the end I did yesterday that I thought was square along the edge and discovered I put a nice crisp camber on the edge (not quite a 45* miter).
So this leads me to some questions:
What is the key to not getting that camber on the edge? Does thicker quarter stock help? Saw someone mention a fence that magnetically fits on the edge of a metal body plane and I have a $20 refurbished #5 coming soon - worth the $45?
I know the head knowledge of not getting a banana but any more tips would be appreciated!
From your description, what you call a camber is a bevel - where the edge you are planing is not perpendicular to the sides. This, and the banana, are results everyone has encountered when they first started learning how to use a plane, and sometimes long afterwards. The best way to learn is to scribe a line around all 4 sides of a practice board. Look closely at this line and its relationship to the edge you are about to try to plane down to this line, and then start planing. Your objective should be to first create an edge that is as parallel and equi-distant to the line as you can make it, and then to slowly bring this edge down to the line. Stop after a few strokes and look at how you are doing, take a few more strokes trying to correct yourself, etc, working slowly to the line. You already know the secret to avoiding the banana. One way to correct the bevel/camber is to use the fingers of your left hand below the plane (assuming you are pushing the plane with your right hand), feeling the board as you plane.
