Infill cap iron questions *PICS*
Dave Thompson
I haven't been around in a while, but it's nice to come back and see so many familiar names. I had some questions about some infills that I recently bought that I was hoping you might be able to help out with. I wasn't really in the market for these, but someone local was looking to unload them, and so I helped him out.
So the first I have a question about is an open tote Spiers which I think is called a #7. It came with a 3/16" thick Hock blade and an appropriate vintage (looking) Sorby cap iron with a bronze bolt receiver. At first, I thought it just need the cap iron screw, though now I'm not so sure this cap iron is even going to work, as the bronze bolt receiver (nut if you will) protrude above the cap iron and will not fit under the lever cap. I'd be interested in your opinions whether I just need to find a new cap iron or other, or whether I should attempt to grind the bronze "nut" protrusion on the cap iron. I'd rather not do that as it looks nice..
The other infill that picked up which needs attention prior to use is a modern reproduction of a Norris A5. It has a Norris style depth & lateral adjuster. The cap iron looks new, though it too is missing the cap iron screw. It's possible I may only need the screw for this one, though screw size is critical for a Norris adjuster as that determins the slop in the adjustment. I haven't been keeping up with the infill kit plane makers to remember who to contact for this, and was hoping for suggestions. The adjuster screw hole appears to be 3/4" diameter. Not sure how much wiggle room is customary for this style adjustor. What size screw do you think I should be looking for? 11/16?
Thanks for your time,
Dave
