Re: Setting up a stanley 39 dado plane
RobertHarrison
Not much response to this, so I'll take a shot at responding. As with all woodworking stuff, your mileage may vary and many ways to skin a cat, etc.
I always thought the nickers or cutting spurs of the 39 were too thick and extruded too far from the plane body on the stock 39 to be useful without grinding to a more knife-like profile.
I don't use them. I score the sides of the dado with a sharp marking knife, then cut the side walls on the waste edge sides with a backsaw and straight-edge guide, then cut the dado with the 39. Then use a small router to clean the bottom of the dado if needed (I prefer the Sargent router w/ 1/4 inch blade to Stanley), and then clean the sides with side rabbet planes, if needed (not often). Sounds like more of a process then it really is, and once you get going you can do dados pretty fast.
