New WoodChat!
A Tale of Two Planes
Texchappy
Been using my Old Street smoother - mostly playing (or is that planing) around - and really love it. I got my 48mm kanna from Stu yesterday. I gotta say great service from Stu, got here from Japan in just about a week.
I got the setup on the kanna pretty good and tried it. First impression was that it was good but the Old Street was easier for me to use. I'll keep playing with it.
I also got my Schwarz hand plane essentials book yesterday and read most of it last night. One thing that I hadn't thought much about or read nearly enough about was grain direction. Armed with this new info I believe I'll be able to be better understand what's happening between blade and wood - at least that's the hope.
Oh, and did put myself on the waiting list for a new Old Street Jack :)) - it's going to be a long six months ;)
Tony
Re: A Tale of Two Planes
david weaver
Keep at it with them, both planes are good planes. You might be able to make a decision about whether or not you want to go one direction or another after another few weeks, and you can revisit whatever you drop (if anything).
If I haven't done anything in a while and I have wood I have to dimension (i.e., i'm out of shape and weak) then I will often use both. I'll pull a jack (one of my cheaper japanese planes ground to a camber) to do the bulk of the work, and then push a panel plane and a smoother.
Texchappy
Yeah, David, I have a suspicion I'll end up using both of these planes a lot. If nothing else, I'll use them on soft and hard woods as necessary.
Brian Anderson Gunsmith
I think it would be planing around, or smoothing around, jacking around, jointing around.
As a gunsmith and dealing with as many threads as i deal with , we talk about screwing around.
