New WoodChat!
wire brushing cast iron lap
les winter
In one of Bill Tindall's posts about using diamond on cast iron as a lap, he mentioned wire brushing the surface and then scratching lines to trap the diamonds. Bill: what is the wire brushing for and how did you make the scratches?
My substrate is un-hardened steel. It doesn't trap the diamond paste I am using very well and needs to be recharged often. I'm looking for why this is so.
thanks
Les
Re: wire brushing cast iron lap
wasn't me and it sounds bogus
Bill Tindall
If one is grinding with say 3 micron diamond any particles "trapped" in a 3 micron deep scratch won't stick up enough to be useful.
I have two kinds of plates. The first were surface ground and I don't recall the grit used-maybe 60. They have a fine scratch pattern and work fine. The second batch we made were Blanchard ground (because it was cheap to do) and that rock must have been "10 grit" because the scratches are deep. I was concerned this surface would be too rough but after a few uses these plates mellowed out and work just fine.
Speculation: I don't think the scratches on a plate contribute anything positive. It is the bulk metal that has to accept the diamond particle.
What particle size diamond are you using? The big pieces don't embed well in cast iron either.
David Barnett
(Message Deleted by Poster)
Re: Cast iron is to steel...
les winter
Thanks, guys. I'm using 1 micron paste.
David Barnett
Re: On scoring...
les winter
Well, I tried it again using a roller made from an old bearing and dowel. Seems to work better.
thanks all.
