Re: Hoop Help - Japanese chisel set up help
TomD
If they are stuck on, I would leave, them. Hold the end on some wood and tap them down further. As long as they don't ride up with every strilke, the wood ends should dome over.
To answer your question, you can hit the head with a small hammer this will cause the ring to come off, or you can hang the ring up on an edge of wood and again punch out the wood.
I really like Japanese hammers, and I used them for chiseling for a long time. But over time I got tired of the noise. I am very noise adverse. So I tried a 20 ounce urethane mallet. Works for me. Hoop setting is not really necessary with the urethane mallet. I have tried a few other mallets by the way, and some of them wrecked the chisels, even with hoops set. One bronze mallet was really destructive.
http://www.leevalley.com/en/wood/page.aspx?p=30003&cat=1,41504,43688
