New WoodChat!
Sawset adjustment question.
John Pappas
Regarding a Miller Falls 214 sawset. There is a small plate near the handle that appears to function as an adjustment for the amount of set to be applied. Anyone have any detail about adjusting that plate? Thanks in advance.
John
Re: Sawset adjustment question.
Marv W
Hi John,
I've not had any direct experience with the MF saw set. However I just now saw one on eBay with some good pictures that shows the plate you ask about.
The plate does in fact play a part in determining the amount of set the teeth will get. As the plate is adjusted forward or back, it will change the angle of the saw blade in respect to the anvil on the saw set. To get consistent set teeth, you must press that plate against the saw plate as you set a tooth. By pressing the front edge of the plate against the saw plate, the tooth is forced against the anvil up above. The anvil also plays a part in how much set the tooth gets along with the angle of the saw plate that is created by the setting of the plate you asked about.
Marv
Thanks Marv!.
