New WoodChat!
Accessory Blades for the Veritas Small Plow
This is a short pictorial on setting up the Small Plow to cut T&Gs. This is a new-to-me plane, and I took a few pics as I was working out the kinks and having a little play. I hope this helps some of you.
Link: http://www.inthewoodshop.com/ToolReviews/AccessoryBladesfortheVeritasSmallPlow.html
Re: Accessory Blades for the Veritas Small Plow
Tom Colligan
Many thanks, Derek. That's a big help.
Is it possible LV will add other blades, i.e. profile blades for beading and the like, for this plane? It seems like it could work, no? Thanks again.
Hi Tom
I cannot speak for LV, but I have my doubts that there will many more blades for the Small Plow. There is a more advanced plough in the works, which will do everything, according the the comments that Rob Lee has made on the forums.
But here's my tip for the Small Plow and profiled blades. I would not want to try and grind A2 steel in case the temper is affected. However, I have used Stanley #45 beading blades in it. They are too long for the adjuster, but remove the adjuster, fit them , and they work just fine. Alternately, make your own out of O1 steel or cut down old #45 blades.
Regards fro Perth
