Re: Run a test.
TomD
Crazy glue. like the fine hot stuff LV sells, or the 4 tubes to a bottle the Dollorama sells, are ideal for this kind of repair. Crazy glue is the universal fix-it for wood turners, and luthiers, and certainly the luthiers are very familiar with hide glue. Advantage to hide glue, particularly had you been the first guy to the party, would be that it is reversible, and not likely to harm the piece.
My advice would be that if you are certain it is maple, or if you have a spot on the base where you can experiment, run a sample of the crazy glue followed by remover. Number one pro thing is not to guess. Always do a sample. Do it on a similar surface and grain orientation. If there was a clean joint it is hard to know why CG would not have worked, and if the parts assemble nicely, CG might still be a good bet. Before you switch to a different tack, you need to know what the result of using a remover will be.
For instance, most acetone contains trace oil pollution, so you are spreading machine oil on the piece if you use acetone. Does that decolor? Does it smear the residue over a wider area.
Everything should be fine, but you need to know, not guess, and tests are faster and more conclusive than even the internet.
