Tongue and Groove Plane
Todd Nebel
The No. 48 Tongue and Groove Plane seems like a useful tool but I haven't read much about it's use. Anyone here use it and for purposes? Can someone point me to review?
Thanks.
Todd Nebel
Thanks.
Re: Tongue and Groove Plane
david weaver
I've used a #49. They work like they're supposed to work (they're easy to use). though I don't know if it'll be enough to get you to seek out places to do tongue and groove. If you have a need for them, they certainly work well. they're set for 7/8ths instead of 3/4ths boards - keep that in mind if you tend to use store-bought lumber.
You can shim the fence on them a 16th to center the groove on 3/4ths, but the groove will be a bit wide compared to the lands.
Hi Todd
I have the LN #49. It is designed to centre on 1/2" boards. Very sweet plane and is both easy and a pleasure to use. Extremely easy to set up.
I used it when building the rear panels of two military chests several months ago ..
Keep in mind that Lee Valley will shortly be bringing out an attachment for the Small Plow plane. This has the advantage of greater flexibility, of being able to work over a wider range of board widths. If you have the Small Plow, this may be a no-brainer. I will write about it in the future.
Todd Nebel
Thanks Derek. That was a good use example. A plow plane is on my list and quickly making it to the top. I heard a rumor that LN may be close to releasing one. So, now I'm waiting to see.
I'm assuming the no. 48 can be used for floating panel grooves in door frames and for edge gluing boards for table tops. What are other practicle uses for the 48 or 49 1/2?
Thanks, Todd
When is LV releasing the plow attachement?
Rob only knows ...
Re: When is LV releasing the plow attachement?
Rob Lee
Hi Patrick,
Should be in a few weeks, almost have all of the blades done now ( there are a lot!).
Cheers,
Rob
