Saw Benches
ron in kokomo
Getting ready to make a couple of these. I have seen several different designs. Any wisdom to share?? I am leaning to chunky with ability to use holdfasts.
Ron a Kokomo Galoot
Saw Benches
ron in kokomo
Ron a Kokomo Galoot
Re: Saw Benches
Guillaume Dery
Ron, I adopted a bit of a hybrid method to play and am super happy.
Dunno if you went through Tolpin's "New Traditional Woodworker". I adopted a lot of his design because I preferred having one set of legs straight and one splayed (thereby allowing me to position 2 sawbenches side by side to support wide rips.
That being said, I like beefysawbenches which do not move for those times where I disregard proper technique and don't stabilize the work with my knee, etc. At the same time, I was also fascinatedwith the sliding dovetails which Roy Underhill used for his Roubo adaptation although I didn't want to use it in a workbench (I prefer all 4 legs perpendicular to the top).
Well, it wasn't long before 2 and 2 made 4. Those sliding dovetails were just the ticket for a beefy sawbench as the entry angle for the sliding dovetail is the same angle as the rear leg splay.
It was a fun experiment which cost me nothing except a bit of glue as I used up offcuts and scraps from 2X stock used in finishing the basement and workshop.
I really like the splayed leg. Tolpin was onto something here. As to the sliding dovetail... overkill but a fun way to experiment with the joint without breaking the bank.
Guillaume
Re: Saw Benches
david weaver
I made a temporary one out of a single 2x12. Every bit of it is 12 inches wide, the top, the boards mortised and glued in place for the legs.
And then put 4 holes in it for holdfasts, left the one end almost flush with the back legs and an overhang of about 10 inches past the front legs that got notched.
Legs is a misnomer, the "legs" are nothing but a length of board that was cut in the middle to make it as if it had tenons on the outsides that could be sunk into notches on the top.
It took an hour. Makes a good seat at the bench, too.
I still haven't made a permanent one. Make sure it's the right height and don't overthink the details otherwise.
Re: Saw Benches
Pam Niedermayer
Huh? Cut in the middle? Of what? As if it had tenons? Either something has tenons or not. On the outsides? Of what? The non-legs? Sunk into notches on the top is the only part that makes any sense at all.
Pam
Re: Saw Benches
david weaver
Cut in the middle of the "non-legs", I guess the ends are then tenons with no shoulders.
Take a 2x12. A "non-leg" is cutoff about 22 inches long. At one end, divide the end into four rectanges 3 inches long (and as wide as the top thickness), remove the middle two with saw and chisel. Cut notches in the top the same size, assemble/glue and plane the top flush.
Sink stretchers into similar notches the bottoms of the "non legs" or the sides for rigidity. Drill four holes in to the top for holdfasts.
Done - very quick and very nasty. Looks like a beginner came to your shop and did it. Works great, you can only cut into it if you make a cut out of square.
