New WoodChat!
LV Small Shoulder . . .
steve mackay
While I use my LV Mini-Shoulder a LOT I had ocasion to reach for the "small" yesterday. The small was a "misunderstanding" or "miscommunication" at Christmas but it did get along well in the chest. A VERY handy tool. It fits in spaces nothing else does. Comfortable to hold. You can flip it over and around in one hand. Takes off "just enough" and is very forgiving. Well made and easy to adjust/operate. And it's just COOL ! If it hadn't been around I'd still be fighting today with the gag I was doing. Another "I've got a tool for THAT" moment.
Re: LV Small Shoulder . . .
Examples.....?
Bill Tindall
I have the huge LN shoulder plane, an ergonomic disaster. However, it has never been too big for any task I encountered. Could you provide some details as to where, or on what, that you find the smaller version useful or even essential? I would not want to be missing a tool purchase simply because I was not imaginative enough to foresee a need.
Re: Examples.....?
Hi Bill
Here is an exerpt from the review I wrote on the LV Small Shoulder plane. I compared it with the LV Medium Shoulder Plane and a Large infill (same size as the LV Large Shoulder).
Here are some reasons to choose a smaller shoulder plane:
Firstly, a smaller plane may better suit a smaller hand. Heft and balance are often a personal choice, in the same way that one chooses a bench plane, above.
Secondly, a smaller plane may better fit the work piece. Consider the most common width of a shoulder. I would estimate that there are more stretchers that are ¾” and under used than those ¾” and greater. Applying the “1/3 Rule”, the tenon shoulder of a ¾” wide piece would be ¼” for the tenon cheek and ¼” for each tenon shoulder. Below are images of the same ¼” tenon shoulder with different sized shoulder planes …
Clockwise: ½” Small, ¾” Medium, 1 ¼” Large.
A third reason is visibility - the larger the shoulder plane, the less easy it is to see what one is doing.
Remember that the Veritas Small is a one-handed plane, where the other, larger shoulder planes are best used with two hands.
In my opinion, a determining factor in choosing a smaller shoulder plane is the ease with which it cuts end grain, especially hardwood end grain. A small shoulder plane may cut softwood end grain or face grain well if the blade is sharp enough, but then lack the authority of a heavier shoulder plane on harder wood.
My experience with the Small was that it manages well with hardwood end grain. I did not find that it was necessary to apply a higher level of muscle power to take a shaving. For contrast, the Small certainly has more authority than the smaller LN ½” Bronze. It lies midway between the lighter LN and the heavier Veritas Medium, the latter of which carries itself even better through hardwood end grain.
Where I prefer the Small over the Medium is that I found it more comfortable to hold for small work. The Small provides more feedback. It feels more precise in what it does. At the other end of the spectrum I find that the large infill has rarely been used over the past few years. It has the highest mass and carries the most momentum of the shoulder planes, but it just feels awkward to hold on narrow shoulders.
Full review article: http://www.inthewoodshop.com/ToolReviews/VeritasSmallShoulderPlane.html
Re: Examples.....?
steve mackay
The first of many "save the day" moves in store for this thing, I'm sure . . .
The up-lock bar on a PERSHING blast deflector.
The "bar" needs to be beveled to allow the up-lock to swing up and engage the bar with less than a millimeter of play.
It's not often that you hear...
Paul M.
.. the term "Pershing blast deflector" in a knuckle dragging neaderthal forum like this one. :D Thanks for posting the pictures of your work!
You should see . . .
steve mackay
how a hundred year old #289 dresses the "ballistic armor" on an ABRAMS tank !
BEST TOOL FOR THE JOB ! ;)
