New WoodChat!
THE WOODRAT IS BACK!
Koyamaichi fishtail
Koyamaichi fishtail
Koyamaichi fishtail
I know Pam and David, and a few others, will be interested in this new chisel from Koyamaichi. David, it is blue steel.
Stu will be getting a few in soon. This one is 9mm wide. There will also be a 15mm wide version.
It appears to have the same high standards set by my Koyamaichi dovetail chisels.
It is a good size, between the Kiyohisa slicks and the Blue Spruce fishtail, and I find it easier to push into hardwood than the BS (which is no slouch). Note that the Koyamaichi is ground and honed at 25 degrees, and the BS at 30 degrees ...
The business end ...
Interesting that the back does not have a hollow ..
Comapred with the back of a Kyohisa ..
Price? I am not sure. Stu sent this to me as a gift. I'm not duty bound to say it is good, but it is good.
Re: Koyamaichi fishtail
david weaver
It's nice to see a moderately priced japanese fishtail that has a profile that's more fitting for western dovetails (a wider fishtail, so to speak).
I have been using skews to this point, but if I do use a fishtail will probably just follow george's suggestion to hammer stock flat to make a cheap fishtail chisel.
I have a still unused anvil (well, unused by me, used by someone else) and need to convince myself that I got it for a good reason.
Re: Koyamaichi fishtail *LINK*
Pam Niedermayer
Thanks, Derek, and Stu, but I use the 10mm (with a much less steep slope) Tasai made; and I found that the only direction I needed to go was smaller, so got one of his 6mm male dovetails.
The problem with 6mm and smaller is it's very hard to make the neck sufficiently strong in a dovetail/fishtail; but still, I don't foresee making dovetails with tails smaller than 6mm (1/4"). In fact, I see no particular use for larger versions and don't really understand why they're made.
Pam
Commissioned Tasai Bachi Nomi
Re: Koyamaichi fishtail pricing
Pam Niedermayer
On the pricing, Stu has about $75 for the 9mm and about $85 for the 15mm, seem very nice for the money. Of course, don't know that I'd want blue steel at all, but few are so picky.
Pam
