New WoodChat!
Another brush cleaning question
What is the best way to reclaim a brush that has been left to harden?
Don't ask me why I'm asking this. :(
Re: Another brush cleaning question
The problem you face
Bill Tindall
Cured oil based products are insoluble in anything. What ever was left in the brush has become on molecule through crosslinking of the the resins.
Some strong solvents like what are used in the best strippers will swell and soften cured finish and it can then be combed out of a brush. If you know someone that works in a lab get them to steal you some methylene chloride for the task.
I've resurrected brushes like yours, Ellis
Bruce, a MN Galoot
For varnish and other spirit finishes, it took several long soakings in paint thinner, followed by brushing with a wire brush (not motorized). Repeat as necessary. I've had good luck with this. However, be aware that this isn't going to happen overnight, maybe several days.
Latex paint? Not so much.
Latex is easy....
John in NM
Quick soak (say 20 min) in lacquer thinner then repeated combing/washing will do it. The paint reacts as Bill describes, kinda softens and wrinkles.
Soap and hot water work marvels on cleaning brushes, and if you can soften the paint/finish at all with solvent and get to the combing and washing stage, you can usually reclaim some very far gone brushes.
Stephen Shepherd
with a hammer
Stephen Shepherd
Take the brush put it on your bench and smash the hell out of the bristles, then put it into some commercial paint and varnish stripper and let it soak until the residue is soft, then clean out with wire brush. Finally wash with soap and water.
Next time, clean off as much paint or varnish as you can then simply wash it with soap and water, yes soap and water will dissolve any type of paint or varnish if it is fresh.
Stephen
Thanks, all
I'll report back on my results.
