The principal of brush washing is straightforward
Bill Tindall
It is a classic problem of serial dilution.
Starting condition and assumptions(for example): shaken or spun or dabbed with towels the "dry" brush holds 25 grams of 40% solids.varnish, equal to 10 grams of varnish solids in the brush.
Round 1 Sozzle the brush in 75 grams solvent. The result is 10 grams of varnish solids in 100 grams total. Shake, spin or dab to leave 25 grams of solvent with2.5 grams of varnish solids remaining (75/100 of the varnish soldids left with the solvent shaken, dabbed or spun away)
Round 2 repeat step 1 with the result of .6 grams of varnish solids remaining.
Round 3 repeat step 2 with the result of 0.15 grams of varnish solids remaining.
If we quit washing at step 3, 0.15 grams of varnish will be left to harden in the brush. (likely unacceptable and one more step desirable)
One can clearly see that the biggest benefit that can be applied to brush washing is to remove as much solvent as possible after each washing step. More washing steps more quickly result in a cleaner brush. Least beneficial is increasing the amount of solvent used in each wash.
Soap is a crappy solvent for varnish. But, it will be effective at dispersing the solvent remaining in the brush in the case where this solvent contains but a small amount of varnish solids(all this has to do with the difficulty of dissolving polymers relative to the ease of dissolving and dispersing something like solvent). The resulting dispersion can be washed out with large amounts of cheap water to yield a brush essentially free of varnish solids. The benefit of the soap is ridding the brush of varnish solids, NOT solvent, which will readily evaporate in time.
The key to employing the soap "trick" is to dilute the varnish solids to the point where soap/detergent will disperse the solvent. If the varnish solids in the solvent are too concentrated the water will crash the varnish out of the solvent solution where it will stick to the bristles, forever.
How much the brush needs to be solvent washed before detergent treatment must be arrived at by experience. The answer apparently is less than I had assumed, but then the answer will depend on the details of the varnish formulation and the detergent formulation. All in all, an excellent idea to detergent wash the brush for maximum cleaning.
