New WoodChat!
More from the Neptune class
Bill Tindall
Will began the class with a demonstration of how one can readily measure and detect differences of 0.001" in various hand tool operations and how differences on the order of a paper thickness (0.003") are critical in good joinery. When using gauge blocks to size a joint component the thickness of the block can be altered by addition of a piece of paper. By making this adjustment Will showed that the result was easily detected by looks, feel and joint fit.
I have seen in discussions the notion of "metal working" precision dismissed as silly for woodworking. However, an optimum glue line in a joint is on the order of a paper thickness or less and to achieve such a glue line requires near metal working precision in joint preparation.
Most beginners and at least this "experienced" woodworker lack either the skill and/or practice to achieve this kind of precision without a "crutch". The crutch Will provided in this class was to use the concept of a reference face, the face of the board from which all joint measurements and fit would be made. This concept in most cases eliminated the need for lumber of precise thickness or width. Furthermore, employing gauge blocks to guide a paring chisel, indexed to this reference face, enabled joints of 0.001" precision to be achieved by even the most novice student in the class.
The pictures illustrates the gauge black for making a dovetail pin on the end of a board and further illustrates thinning the pin by one paper thickness to demonstrate how just 0.003" makes the joint too sloppy. Similar gauge blocks were used in preparation of dovetail sockets and tenons.
There is nothing like the success of preparing a precise fitting dovetailed drawer blade joint in a short amount of time to convince even power tool enthusiasts that hand tools have a place in all shops making fine furniture. Having slid down the slippery slope of hand tool usage, crutches like those illustrated will help some climb back up the learning curve to making fine furniture.
Re: More from the Neptune class
Hank Knight
Bill,
Thanks for posting this. Many people poo-poo fixtures and jigs as "training wheels" for hand tool beginners. I consider myself reasonably accomplished with hand tools and I find some of these aids invaluable in achieving very close-tolerance joinery. They may be "training wheels," but I don't see myself ever becoming skilled enough to accomplish that level of accuracy without them.
Hank
david charlesworth
Bill,
That advice is spot on.
The old argument, that precision is not required as wood moves, is one of the great woodworking myths. Cigarette papers, parer and card, play an indispensable part in my work.
I have quite a collection of these (myths).
Best wishes,
David Charlesworth
It's good to see you back, David.
