New WoodChat!
sharpening a hand scraper
eliot d
I learned to sharpen these by first filing, then using a stone, then "stickering"( I think that's the term) , then burnishing. But I saw a demonstration where the guy only filed and burnished , and it seemed to work fine. What's the correct procedure?
Re: sharpening a hand scraper
Jack Guzman from Maine
Just filing can leave irregularities. The stone just brings it down to a smoother finish. Probably not necessary with a fine sharp file if you file straight down the length of the scraper. I'm no expert ,just seems like common sense---Jack
Paul M.
If I use a scraper to level finish, then I polish the edges and use the scraper without burnishing. That always works best for me on taking off the smallest curlies of finish.
If I'm scraping wood, then I usually just file the edge perfectly flat using a fine mill file, and then use the burnisher to raise a curl. I don't bother with the stones as it seems kinda pointless to me. I can get a good edge with the file.
After a dozen or so resharpenings, I will polish the edges again as they pick up nicks and wear along the way. But not for every time I raise a curl.
Heck, sometimes I just burnish the curl back down to flat and raise it again. Works for me if I'm in a rhythm and don't want to break more than a few seconds. But the curl will be fragile and it won't work for as long.
TomD
Scrapers can be fluky to sharpen, but there are also lots of methods that work. Most commonly I just push them against a belt sander, and then burnish them. That may not be perfect but it is almost instant, which counts for a lot. But I have used the stones and all that, and the fact that scrapers are super cheap leads me to use the faster method, even if it takes away a little more metal.
depends
ron in Kokomo
The finer the work I want to do with a scraper, the more time I spend preparing the edge. The closer I am to applying finish, the more I want my scraper as good as I can get it.
Ron in Kokomo G.O.O.N.
