New WoodChat!
Millers falls 14" brace
wanda
Hi,
I"m not too familiar with braces so I'm in need of some advice. If you had to choose between a 10" brace and a 14" brace which one would you pick?
I need a brace so I can bore 3/4" holes in the top of a 4" thick bench. (Roubo bench) I don't know of any other tool that is capable of that.
wanda
Re: Millers falls 14" brace
Chuck Bjorgen
I'm still a bit new with braces and auger bits myself but I think you'll find that the 10" brace is the most common. Theoretically, I guess, a 14" brace would give you more torque, but I believe the augers should tend to pull into the wood on their own with the screw points. I just picked up a 10" brace on an auction site for 99 cents and about 10 bucks shipping. Also got some auger bits, which I could see needed sharpening and just did that this morning after getting the proper files from Lie-Nielsen. Lee Valley no longer has them.
I'm currently waiting for the right deal on an 8" brace.
Pam Niedermayer
Boring holes in benches is incredibly hard work; so I'd aim for the most torque I could get, probably the 14". However, that requires a pretty long arm span, so if that takes you out of a strength position, aim for 12". And be sure and sharpen those bits. :)
Pam
wanda
HI,
That is amazing.. .99 cents for a 10" brace. Seems you can get a lot of things for less in the States. For a Milers Falls 14" brace I'm looking at $50.00 plus the cost of shipping and handling which will be around $20.00 Canadian.
Yup the 14" brace would give me a lot of torque but it's probably overkill. Yeah most people say the 10" brace is more popular. A general all-around user.
wanda
In my limited experience, 3/4" is about the upper limit for me in most woods (tall, but not a weight lifter). A 14" brace will definitely get you there for that application, but is awkward for general use.
10" is the most common swing I see at garage sales, indicating that it was the general-use brace of choice when a brace was how you made holes larger than 1/4". There is also, of course, the 12" swing, something of a compromise; less common than the 10", more so than the 14". You could probably use a 12" swing brace for daily use, if you're 5'6" (167 centimeters) or taller; if you're short, you'd find a 10" far friendlier.
Make sure your auger bit is sharpened well, that the length of it is bright and smooth, and that the screw at the center is bright and clean, with no bunged up threads. And have plenty of liquids and some aspirin (or similar) available. You may need it.
Hi Wanda
I thought that I had grabbed a 12" brace to bore 3/4" into the oak bench top, but later I realised it was a 10". It was still quite easy with that size - just make sure the bits are sharp. A 12" would be a better compromise (than 14") for a 3/4" bit into 4" thickness.
Bob
bob
Couldnt you borrow a boring tool used by Timberframers to do the job easily? You wouldn't break a sweat? Even a 2" hole would be no problem.
wilbur
I have a 10" brace and I happened upon a 14" brace just as I needed to drill 3/4" holdfast holes into my Roubo bench. Having the 14" brace was completely worth it. It was much easier with the extra torque.
I don't remember exactly how much I paid for it, but I don't care. It was worth it.
Pam brought up body size. I'm just 5'6", and I didn't find the 14" brace cumbersome to use.
One piece of unsolicited advice: take a scrap piece of 2x4 and drill a 3/4" hole through it with a drill press, and use that as a guide for your brace and bit when drilling the holes through your Roubo workbench top.
wanda
HI,
Thanks guys for all the helpful comments.
One more question when it comes to braces... Would I be better offf purchasing a 2 fluted auger bit with a threaded point or a 1 fluted auger bit with a brad point? How does the Jennings pattern bit compare to the much less expensive LV auger bit? How about the Irving auger bits. Are they any good? I've heard the Jeenings pattern bit is one of the best but it doesn't come cheap. ($38.95 US) for a 3/4" pattern bit.
wanda
For a brace, the traditional bit has a threaded point. This will pull the bit through the wood, translating your round and round movement into forward movement through the wood. A brad point would require you to turn and push at the same time; you can do it, if you can get behind the brace, but your fun quotient will be low.
Jennings bits are considered the traditional hardwood bit; the screw point tends to be fine thread, resulting in lower speed/thinner chips/easier penetration of hardwood (you haven't mentioned whether your benchtop is hardwood; most of the Roubo benches folks are making are).
Irwin bits are considered softwood bits, although some folks report decent performance in hardwood.
If you have the time to apply elbow grease instead of money, I could send you a 3/4" Jennings bit for the postage, although this would be US$13 - I'm assuming that you're in Canada from your e-mail suffix (if you are in fact south of the [Canadian] border, it'd obviously be cheaper. It would need some cleaning up to be smooth enough for good boring. E-mail me if you're interested.
wanda
HI Wilbur,
I have a choice now between a 14" Millers Falls lions chuck brace or a 12" Stanley 914 12" brace.. not sure if that has the nice cocobolo handles like the 14" brace.
Too many to choose from. One brace can't do it all I realize that. The 12" is tempting. I don't know much about the history behind the Stanley braces but I do know that Millers falls were some of the best made in their time.
The guy I'll be purchasing the brace from went on a buying expedition over the weekend and picked up a few 10" braces. So I have to decide if it's going to be the 14" 12" or 10" . Heck I'd love to have them all. I need a brace that will bore a big 3/4" hole... plus bore out the waste in the mortises underneath the benchtop for the leg tenons.
wanda
wilbur
I'd vote for the 14" Millers Falls brace. You won't regret it.
You'll want to have a 10" brace at some point. But they are pretty easy to find compared to a 14" brace. Given your immediate need to drill some 3/4" holes, I'd get the 14" brace in a heartbeat.
Chuck Bjorgen
Sounds as though you're buying locally. Any chance you can try out the various sizes to see which is best for you? Bring your 3/4" auger bit.
wanda
Hi chuck,
Wish I could try out the brace before but I"m purchasing it from a guy out west. Not easy if not next to impossible to find antique handtools where I"m from.
I think I might just purchase the 14" brace. If I find I need a smaller brace dwon the road then I'll pick one up. I'd like to find out more info about the 12" Standley 915. Have no idea how they'd stack up against a Millers Falls brace.
I have a little bit of time before I make up my mind. .
wanda
