Re: Wenzloff
Schtoo
They're (unfortunately) notorious for this kind of thing, but it's consistently said to be unintentional, they're just being overwhelmed continuously.
Previously, I thought it was a bit of a cop-out, but I can now sympathize somewhat.
(I run an internet based store some folks here are aware of.)
Since the start of this month, I've had a forced 1 week trip to Australia, and coming back to Japan got a nasty dose of the flu. In that first week, things were quiet. At the end of that first week, things went double nuts crazy and now, nearly 4 weeks after my world did a loop, I'm only just now starting to get back on top of things.
I'm still behind with some things, I'm not sending out anywhere near as much email as I would normally and I'm only acknowledging emails that I can answer quickly and get them 'done with'. The bigger stuff, not much yet.
If I had not been knocked flat on my back with 'a cold', I'd probably not be so far behind. But having a light week of backlog, then an extra heavy week dumped on top of that and another 'normal' week, all while still not at 100% operating capacity and trying to do the extra work as well.
It's tough. No other way to put it, it's tough.
For me, I've decided that until I'm back on top of things properly, the little niceties can be put aside so long as I get stuff out as fast as I can, answer what emails I need to as fast as I can and actually get back to the rest as time allows is the best plan of attack.
I figure by mid-week I'll be on top of it, but I'd much rather never have had the interruption.
In Mike Wenzloff's case, I believe it was a longer, more drawn out case of 'diminished capacity' and the associated backlog that naturally brings when business is doing even moderately well. Other folks can give more details, but speaking only for myself if I were much further behind than I was and I knew I wasn't going to be able to clear things up in the time I am right now, I'd be switching things off.
It's maddening enough that I can't do the job the way I like to do it right now, but it can't be helped and thankfully, I don't think it'll be something I need to do regularly. At least, I hope not.
That's not excusing the lack of contact you're getting at all, just my take on it. Like I mentioned, before this month I had little sympathy but now, I can understand.
(Turning the lights off on interweb based stored is nearly suicide. Once folks realize "it's closed", they tend to not come back. A site that's off line is ok, down for maintenance is ok, temporarily offline for an emergency or natural disaster is fine. Lights off, they're gone and folks will look elsewhere. A brick an mortar store doesn't have that problem, since folks do need to go home and go to bed and most people understand this. Not on the internet though.)
Good luck,
Stu.
