What are these?
Pam Niedermayer
Does anybody know whether these are thread chasers, somehow or other for a specific lathe?
Thanks,
Pam
What are these?
Pam Niedermayer
Thanks,
Pam
Re: What are these?
They look a little bit like the inserts you find in some pipe threaders; but, assuming the numbers on the piece in the center represent diameter/pitch, they're not any standard thread, pipe or otherwise. And they don't look to be tapered, as pipe threads are.
Odd.
Dad said . . .
steve mackay
My tame tool & die maker (Dad) said :
"Rambold Turret Lathe
Google this website and see the threading head do its work on utube"
Re: What are these?
My guess is that they are early 20th century peach fuss groomers.
T.
Re: Dad said . . .
Pam Niedermayer
Please pass on my thanks to dear old dad, fantastic video. Do you think they could be adapted to use in a wood lathe for threading?
Thanks again,
Pam
Re: Dad said . . .
TomD
If you want to strike a thread those cutters are different in that they have a tooth that is even across. These seem to have some lead in. I don't doubt one could strike something with them, but maybe not the classic application, which is tough enough with real tools (that are relatively easy to make). I have a couple of sets if you need dimensions, or presumably someone still sells them.
Re: Dad said . . .
Pam Niedermayer
Thanks, Tom. I thought they looked kind of unsuitable, but so do the wood thread chasers. I don't understand how a good thread gets made with chaser applied to spinning spindle, seems so haphazard. I'll keep trying.
Pam
"Holding" . . .
steve mackay
As The Boss' discipline is steel and mine is wood I'm told "not worth it" a lot. With these, going from a turret metal lathe to wood lathe (and I'm NOT a lathe guy by any streatch !) you'd have the riddle of "holding" and "applying" the tool to the workpiece at proper (get this !) angle of attack, sine variation, speed rateing of the tool, yadda, yadda (read : machinist speak
). But then, if we're set on useing a tool, there's always a way. And sometimes it DOES do the task better !
Probably ! . . .
steve mackay
LOL ! He thought that was funny. He said, now days, with all the new equipment and machines, THAT might be the only use for them left !
Re: Dad said . . .
TomD
When you say you don't understand, I assume you mean you know, but it hasn't happened for you yet. I learned from Bill Jone's book, the tools I have are just for little pieces, boxes and smaller. Sure is a knack to it, and I could never feel any great certainly about it.
Re: Dad said . . .
Pam Niedermayer
Yeah, I can't seem to conceptualize thread chasers to an end product. I've made wooden nuts and bolts, but only with those threading kits; and I've tested making St. Roy's version, applying a single cutter for both nuts and threads; but how a thread chaser makes a thread is beyond me. It seems they'd just make concentric and unconnected round gouges on spindles. Somehow they do more.
Pam
Re: "Holding" . . .
Pam Niedermayer
I figured out a potential way to hold them, but when it came down to it, I had little confidence of my being able to successfully make wooden threads with them. That video was very good, but made it look more mysterious, what with that housing covering the threads for the end step. So, I didn't bid. Thanks, Steve.
Pam
