New WoodChat!
working link to Patrick's Blood and Gore -- OT?
Ian (in Sydney, Australia)
as you can see from my name I'm in Australia.
for reasons I can't fathom, the address (www.supertool.com) for Partick's descriptions of Stanley planes no longer works
I know the site remains live because with a bit of effort I can access an archived version of each page dated in many cases less than 48 hours ago.
So I'm guessing the problem lies in a DNS server somewhere that has a corrupted lookup table.
Does anyone have, or know how to find, the full DNS address -- the nnn.nn.nnn.nn numbers thingy -- for the "blood and gore" home page
Re: working link to Patrick's Blood and Gore -- OT?
Brian Greene
Just went there from Ottawa without difficulty.
LRSmith
Re: working link to Patrick's Blood and Gore -- OT  *LINK*
See if this link works
Thank you BUT ...
Thank you for posting the link, but my problem seems to be a related to some issue between by ISP and Patrick's site.
I know the site is active and I can access copies of Blood and Gore cached by Google but whatever I try I can't get to the actual site.
When I click on a link that works for others, or enter the www address, I get the following message:
Oops! Internet Explorer could not connect to www.supertool.com
Suggestions:
•Access a cached copy of www.­supertool.­com/­StanleyBG/­stan0a.­html
•Try reloading: www.­supertool.­com/­StanleyBG/­stan0a.­html
•Search on Google:
I've tried manualling configuring the DNS server my ISP uses, but no luck
I'm at a loss and looking for ideas
Re: Thank you BUT ...
Guillaume Dery
I've just pinged supertool.com.
Try this first. If you don't get a reply via ping, you (your ISP) has a DNS issue (alternately you can do an NS lookup which will get you the same results). If indeed it doesn't resolve. Try a DNS flush to see if the problem is with you or your ISP.
Open the Start menu.
Go to Run.
If you do not see the Run command in Vista, search for "run" in the Search bar.
In the Run text box, type: ipconfig /flushdns
Press Enter or Return, and your cache will be flushed.
Also, as my ping worked, here is the resolved IP address: 66.205.75.11. Here is the bad news however: net1plus.com also resolves to that IP address. Net1plus is the site host and unless we know how they structured their sites, you can't http to Patrick's site via the IP address ( I know, I just tried. They also don't have a default page setup. sloppy configuration on their part).
So if you don't resolve, contact your ISP to have them address the issue. This is part of what you pay for.
Cheers,
Guillaume
