New WoodChat!
Travisher options...
Scott in Douglassville
Hi, all -
I'm getting back into chairmaking after a bit of a break. A lot of relearning going on, largely with the help of Curtis Buchanan's and Peter Galbert's sites. They both speak lovingly of Elia Bizzarri's travishers, saying that the 4" radius is perfect.
Now, years ago, I made a travisher with one of Drew Langsner's blades:
Turns out the radius is a little less than 3". I'm pondering now buying a larger radius travisher to augment this one. Have it down to two options, and I'm wondering if folks have used either/both and have any sage words for me.
The first is Elia's: http://www.handtoolwoodworking.com/tools.html
The second is from a guy in the UK, which has a little larger radius yet: http://travisher.com/
So, anyone have opinions on these two tools?
Thanks for your thoughts.
Scott
Re: Travisher options...
Pam Niedermayer
Have you consider using a curved drawknife instead?
Pam
TomD
The guy I was taught by was in the Windsor institute frame of reference, and he use an inshave followed by a compass plane, followed by a travisher for finishing, which surprised me since I normally think of planes as more for finishing than spokeshaves, but maybe with the endgrain saddling seats, the travisher does a better job with it's low blade angle. I think if I had to make do I would either make a low angle plane, or reform the Langsner version, which is also the one I have. I don't know about the currently existing makers.
Pam Niedermayer
Those seats are such complex surfaces that I'm not sure how a compass plane would work, maybe if it had handles on both ends so you could work it like a transverse travisher. It all gets scraped and sandpapered and painted in the end regardless, kind of screams for a good Japanese bladed compass. I also wonder how a yarikana would work.
I've got a travisher with stumps for handles, kind of like that travisher.com product, that works great on bowls.
Pam
Jack Guzman from Maine
Pam,
The way I learned it,the inshave is the roughing out tool.The travisher is used to remove the ridges left by the inshave.Both are needed.---Jack
Tom,
My compass plane has a wide mouth,similar in function to the inshave. It works alot like a scrub plane.The travisher however has a close mouth and takes a relatively fine shaving. ---Jack
Jim Crammond
Scott,
I've made several travishers of different radii, it's pretty simple to do. I've used O1 steel(3/4" x 6" x 1/8" or 3/16"), cut it the desired shape then bent it cold. This is done by cutting a block of hardwood (about 2" x 3" x 1.5") near the middle of the longest face at the desired radius. Using a machinist's vice as a press, place the blade between the two pieces of wood and tighten. Usually you have to start at the middle, work your way out then 1 last press in the middle to get a fair curve. Heat the tangs with a torch and bend so they are vertical with respect to the the middle of the blade. The last step is to heat treat the blade.
You've mad a body to fit the blade you purchased so you know how to do that.
I know this is a pretty quick summary, so if you have any questions just ask. I think John Wilson (of Shaker oval box fame) is publishing a book about making tools that will have a chapter about making travishers. He also offers a class at his shop to cover the process, but I think this year's class was a couple of weeks ago.
Jim
Pam Niedermayer
Yes, of course you're correct. I was talking about a very sharp, slightly curved drawknife as a finishing tool, based on Buchanan's video. He used scrapers and sandpaper as the last steps; but the look of the wood straight off the drawknife (when he started carving the sweep) was extraordinary. Please keep in mind that I also love the look of "unfinished" wood as planed, so I may not be the best judge.
Pam
ask the source
Bill Tindall
Ask Curtis. He is a great guy dedicated to teaching. I would be astonished if he didn't reply to your question.
Re: Please email me dude!
Dude, check yer email. Let me know if it doesn't get through.
Re: ask the source
Steve Kirincich
I haved used An Elia-made travisher while taking a class with Peter Galbert, and I highly recommended it. I think it helped that Peter does a great job of sharpening his tools.
Steve
