New WoodChat!
wooden wheelchair
wooden wheelchair
Jack Guzman from Maine
wooden wheelchair
A friend gave me a wheelchair that was rotting away in her basement. It has an oak framed seat with woven cane. I want to restore it. It's still all there and functional. It just suffers from being in a damp area for too long. The only part that I can see being troublesome is the wooden handrims on the wheels. They have lost their roundness,come apart at the joint that joins the ends of the hoop and split in several spots where the grain runs out. I think the best bet is to try and replace them.Does anyone know of a source for such an item? I have all the hardware,I just need a wooden hoop.
If I can't find replacements I'll probably build a steam box shaped to fit them and try to rebuild them around a form of some kind.---Jack
Re: wooden wheelchair
TomD
They aren't particularly difficult to build. They do sell wooden bicycle rims, I am not sure if you can find these without the drilling, the glue-on tire models which are more common in this segment, are nearly round in cross section. There is a good youtube video about making wooden tire rims in the Italian factory that still does it. Quite detailed. They use a lot of specialized machines, but the real gold is stuff like the dimensions pre bend, etc... There would also be a level below which the wood would bend without any heat, or would bend merely from soaking in water. The only problem with steam bending is that in order to go around a few times you are going to need a very long steam box, of take it in steps. I don't remember the factory having a long box. But if you could cold mold it, it might be easier, and it would be stronger.
If I can't find a ready made wooden hoop(which I think is the case) I won't make one from scratch. I will just take the old hoops and put them in a square steam box built to fit and set the hot hoops on a form and attempt repairs before cooling. I'm not sure how this will work but it's worth a try. A long box would be easy,just use 4" pvc pipe. That will be my last resort if repair doesn't work.---Jack
