New WoodChat!
THE WOODRAT IS BACK!
Thinning Titebond Glue
Barry
Sometimes, it seems that Titebond, out of the bottle, is just too thick for some purposes. I sometimes thin the glue with just a bit of water to adjust the viscosity. Also, as glue bottles approach empty, the glue seems to thicken and I thin with a bit of water. I have seen no indications this hurts joint strength or anything. Does anyone else do this? Any comments?
Re: Thinning Titebond Glue
An acceptable practice
Bill Tindall
The makers of Titebond recommend thinning with up to 5% water for some applications, or when water has left the container either because it was left open or it is a very old container and some water was lost through the container sides.
They also caution that thinning the whole bottle with 5% water and forgetting this event and thinning again, and again , is not a good idea.
Thinning slows down the cure time for better or worse.
Re: An acceptable practice
Barry
Thanks.
Paul M.
I've thinned titebond 1 quite a bit when using for veneering applications. No problems other than longer time to cure.
Barry
I just wanted to be sure I wasn't committing some unpardonable woodworking sin. It hasn't seemed to cause any problems. :-)
