New WoodChat!
Nick in plane sole
Nick in plane sole
Nick in plane sole
mdelgado
I'm a newbie, so forgive me for asking a dumb question. I was planing with a LV Low Angle Jack plane when I got a nick at the very top of the adjustable mouth. (The plane accidentally hit another piece of metal on the bench). As a result, it now leaves scratches in my surface. Any suggestions on how I can quickly eliminate this little problem? I was going to grab a file, but I thought I'd check with the pros first. Thanks.
Re: Nick in plane sole
craigd
craigd
I personally would use a fine-ish stone and hone it out; if you aren't careful, a file will leave lots of scratches (not that it would matter but it is annoying).
Bill Tindall
I like the stone idea but I would likely use a small fine toothed file if the file will reach where it is needed.
Guillaume Dery
Wet-dry sandpaper, jsut like if you were flattening the sole
Jerry Nicholson
I used a file to get the nick out of my LV plane. It took me about 2 seconds. I don't know if it came with the nick or if I bumped it on a steel bracket.
Jerry
My choice would be a fine diamond stone, such as a 600 grit.
It is possible to get these on paddles as well, or even make up a paddle by glueing Wet&Dry onto hardwood.
Wat you must be wary of is creating a depression. This would be the same as having an open mouth. You want to remove the nick and smooth it flush with the sole of the plane.
