A new type of shovetails?
Chris Scholz
Spring in coming in TX and we decided to get an early start on seeding this year. To avoid a late frost from killing our seedings I decided to make a few cold-frames.
Of course one could simply nail together a few boards..., no, that would be too easy. No frames without hand-cut dovetails in my garden.
As is the course of nature though the sun does not really care much about my hand-cut dovetailed coldframes: In winter straight sided boxes cast shadows on the tender vegetables do not get an optimal exposure to the sun.
The solution is of course a cold-frame with slanted sides. After a bit of poking around the web, sure enough I found detailed instructions on how to build such boxes using traditional methods.
The first attempt was less then stellar:
and sure enough, I did not understand one of the steps they outline in the instructions.
I guess I can declare the second attempt a success, although, there's still a long way to go before this will be fine furniture grade joinery.
BTW, if you take a close look at the "dovetail formula" you'll notice that this formula is only valid for board that are much thinner than they are wide, which I'd say is almost always a correct assumption.
Thanks for listening.
