Dunlap plane query
Bill Tindall
I sold someone some surplus oak and during the negotiations the customer mentioned that he had a plane, that didn't. He had taken a class at Woodcraft where it was "sharpened". (microbevel on wrong side, was not sharpened to the very edge and it was not straight across the edge). little wonder it didn't pick up a shaving as it was dull and had no clearance)
I said I would take a look at it. It was a Dunlap #4. It seemed a cheap looking plane, but it was a good opportunity to teach the owner how to set it up. I checked the chip breaker and while it looked to be of poor quality it was in fact the straightest I have ever encountered. Only needed polishing. The owner was a machinist and I set him about straightening the edge and establishing a hollow using the grinding wheel. He did well, but then he has probably spent 10X more time at a grinder than I. He did allow that he would have jigged up the blade and done this job on a surface grinder. I started him with a honing jig on abrasive sheets. When I showed him the technique I became immediately impressed with the steel in this plane blade. This blade sharpened like a high quality replacement blade. It was exceptionally abrasion resistant as judged by how it performed on the abrasive sheets. It took a keen edge and made shavings that left the owner smiling.
What is the deal on Dunlap planes? I never heard of them. It looked cheap but it performed well. The steel in the blade was outstanding; better than any Stanley steel I have encountered.
PS He also brought along some WoodRiver chisels. I didn't get to check out the steel but the fabrication quality was exceptionally poor. They did look attractive if one didn't look too closely. Amazing how polishing a crummy grinding job can apply the appearance of quality to a chisel.
