New WoodChat!
sharpening/ jigs
sharpening/ jigs
sharpening/ jigs
Rick Snyder
Hello All,
I have three questions,
1. Where can I find the info. on how to make the "jig/scale" that is used to find the degree of angle when you take the edge of a board and measure so many inches inward and draw a line and that line represents the degree of angle? I've seen this done on several videos. I would like to try that approach.
2. At what degree do you hone mortise chisels, I bought a set that I have not used yet.
3. Has anybody here used the approach of using only various honing compounds (grits?) on MDF to achieve a sharp edge and where would you buy a set of compounds like that? I heard a MDF disk was used on the Worksharp sharpening system.
Thank You,
Rick
Re: sharpening/ jigs
wilbur
1. Here's a link to Lie-Nielsen's sharpening jig plans: http://www.lie-nielsen.com/pdf/AngleSettingJig.pdf
Keep in mind that the exact distance isn't crucial. The purpose of this jig is to help you set your honing guide consistently. If your jig gives you an angle of 29.7º instead of 30º, as long as it always gives you 29.7º, it's doing its job.
2. Mine are at 30º. If they start chipping, I'll raise it to 35º, but I haven't had to do so yet.
3. Can't help you with the MDF. I use waterstones.
david weaver
3. I would depend on something else for the coarser grits, unless you have something to power the MDF. You could stick PSA sandpaper to something, or use some mild steel or cast iron and use diamonds at the 1000/2000 grit level.
Autosol or chromium oxide powder/paste/stick is fine to use on MDF. Autosol will make a pretty fine edge, but it does leave a film of black stuff on a tool.
Rick Snyder
THANKS!! To Wilbur(my dads name also) and David for the great info!
Hi Rick
Firstly, the distances on the jig (for the blade projection to achieve honing angles) will differ for each honing guide. The simplest way to find these angles is the draw the angle on a sheet of cardboard and stand it up alongside the honing guide ...
Since you are planning on using MDF as a substratum, if you do not as yet have a honing guide, consider making one designed by Brent Beach. Here is one I built (in the system I mention below) ..
Lastly, here is a link to a short article I wrote on a MDF/rouge-based system. Actually, all you need is a small section of 600 grit wet-and-dry sandpaper and Veritas green crayon (0.5 micron).
http://www.inthewoodshop.com/WoodworkTechniques/The%2010%20Cent%20Sharpening%20System.html
Curt Putnam
Somebody may have made an MDF disk for the WS 3000 but as supplied by the mfg, the disk are glass upon which one affixes PSA sandpaper. They do have one disk with leather mounted on it for use as a power strop.
AZ in Colorado Springs
I have a worksharp 2000. It used slotted plastic wheels; no MDF.
