Re: Shop-built toothing plane help
TomD
Dean Torges turned a lot of people on to the toothing plane. His recipe consisted of bedding a ECE cutter at 75 degrees. His wedge was 12 degree, He opened the mouth at 87 degree, in the direction of the blade. He then drew a line at 55 degrees from say 1/4 ish above the mouth, this leaning back away from the iron. Then up that a bit he hogged out a big bay with a 2 inch radius. So the blade was bedded at 75, the mouth was a just less than vertical, and towards the blade, then leaned way forward, then a lot of wood was simply removed to provide room for the shavings.
Torges makes simple sawn planes like the Krenov ones, but used a dowel retaining pin.
This plane was designed to enhance glue joints and plane very difficult woods like Osage. Torges is a bowmaker, Osage one piece bows have to be pretty nice wood, but Osage bows that are backed, can use more normally occurring boards, and they are some of the worst for tear-out on will find.
