New WoodChat!
flatten water stones
Bob
Bob
I have two nice Japanese water stones, 800 and 1200 grit. I usually true them on my bandsaw top with fine sandpaper and supper 77 to stick them.
I would like to move to a diamond stone but not sure which one to pick. Does anyone have any recommendations?
Bob
Re: flatten water stones
david weaver
Look up the following on amazon:
W8CXNB
That will bring up a DMT duosharp. That is the cheapest "good" option, and should have grits of something like 220 and 325, and be flat, too.
You can get a slightly cheaper DMT if you are comfortable with 325 and 600 grit, search this:
WM8FC
If you want to spend more money, an atoma is slightly nicer, but it will cost you a lot more money to get it with current exchange rates, and it will be one-sided versus two.
The two-sided nature of the DMT lets you use one side for stones and actually use the second side on metal.
You do not want to use a side to sharpen a bunch of metal tools and also flatten waterstones if you like how fast DMT (or any diamond hone) flattens a stone when it's new. They are miles slower at flattening waterstones when they've been worn dull by sharpening tools on them.
your flattening technique
Jerry Gibbs
could you explain your technique using a band saw?
Bob
Re: your flattening technique
Bob
I use the table top of the band saw. 5 years ago I bought a MiniMax 16" band saw. It is the highest quality tool I have. I spray 3M 77 adhesive to the back of wet/dry sandpaper for truing up water stones. It's a mess though - have to use a petro product to clean the table top. Just looking for a better way.
Bob
An alternative flattening method
Steve Elliott
Another option would be to use wet/dry sandpaper on a granite plate. The granite is very flat and the sandpaper can be wetted so that it sticks to the granite without adhesive. I flatten my stones as a part of my sharpening session so that they're flat every time I finish sharpening. Years ago I tried regular sandpaper on a jointer table and hated the way it got grit all around.
TomD
Just be sure whatever stone you buy is designed for this use. I have ruined several by flattening water stones with them. The diamonds are fine, but the vitreous bond used to hold them in place is softer than whatever is in the stones. You can flatten these stone by just rubbing them together. Or you can buy another 800 grit stone, and rub the 2 800s together, then just flatten up the line. These stones have been around a lot longer than diamond "stones". Sometimes the old ways are best, but seem to involve some difficult skill. Here they are simple.
Re: flatten water stones *LINK*
Paul M.
I bought a Dia-Sharp D10C (course) plate and use it exclusively for flattening waterstones. It only takes about 5 seconds to flatten a stone at the sink. It's a big 10x4 size so it works great for stones that are the typical size (smaller than 10x4).
Got mine here
Brian Greene
I use 120x drywall screen, specifically Norton brand because it's wider and I have found it to be reasonably durable. Don't use cheap stuff. At home I use a machinist plate as a reference surface; at work I use plate glass. The method is a mix of old and new: the coarse stone on the drywall screen, all sides/long edges as appropriate. I then do the medium on the coarse and the fine on the medium. I also lap very frequently, typically every time I sharpen more than a couple of tools but not more than every 5-10 minutes of use.
