New WoodChat!
A bracing question about braces
This is a building trades question, rather than a shop woodworking question.
I've seen the big elaborate corner braces (as in brace and bit, not hardware) now and again, always at prices I couldn't justify for what would likely be a decorative rather than frequently-used tool. But I've found them intriguing; they seem to have been designed by the same person who laid out the water supply lines under our house (some of which went in every conceivable direction, up, down, and sideways, within a "box" of about one foot in order to turn a corner). A couple of weekends back, this one (Millers-Falls 502B) followed me home, as the seller was asking a very low price for a tool in decent shape:
These are usually described as electrician's (or, occasionally, plumber's) tools, used for boring in tight spots to get conduit/pipe/cable through wall framing. But, as I looked at it, this made less and less sense. The tool alone is 17" long, and wouldn't fit in a standard 16" on center stud bay, even without a bit; and likely not in a 24" on center bay with a bit. It seems to me that it would be useful only for drilling the bottom or top plates in conventional framing. Yet, it must have been useful; I found the design first in a 1914 Stanley catalogue (it may have predated this catalog; it was just the earliest one I found in a quick Web trawl), and it still appears in the 1958 Stanley catalog. Certainly, you can apply continuous turning pressure with it, a possible advantage over a ratcheting brace; but for boring what holes?
The other corner brace design, typified by the Stanley No. 984, seems like a much more logical tool for working in stud bays. It was offered concurrently with the brace design above, as if the two were complementary tools. Perhaps the expectation was that the mechanic would buy both, using them as appropriate.
Google got me nowhere; no one seems to know more about them than I do, which isn't much. Anyone happen to know their historical uses?
Re: A bracing question about braces
James Watriss
Electrician's? Dunno.
Knowing little else, the configuration of the outer handle looks like a concession to a need to drill large-bore holes. (ie, a wider swing, to provide greater torque) This sounds like something a plumber might need.
If it's an electrician's brace, I have to wonder for what kind of work. Given that early wiring was tube and button, not romex, and that balloon framing was subtly different from stud framing, in-house wiring was most likely different from what we know. But if said electrician was boring big deep holes in phone or telegraph poles, a big swing might again be a very relevant feature. What were they wiring up? Houses, or towns?
No real information here, just musings...
Warren in Lancaster, PA
A lot of early 20th century work was retrofit, adding heat and electricity, sometimes in stone houses. They often put pipes and wires in the corner of the room, the wires in conduits. Sometimes the corners were boxed off, sometimes not. If you are making a hole through the floor as near to the corner as possible, a ratchet gets less than 90 degrees of swing. Here your brace would be pretty helpful.
Re: A bracing question about braces *LINK*
Patrick Gibbons
The top brace is called an angular brace. I've linked to the patent, which is #859059. It was designed to use over obstructions, as the patent says, while the second was designed to be used in tight quarters. Two different uses.
http://patimg2.uspto.gov/.piw?docid=00859059&SectionNum=3&IDKey=A66E8776DC52&HomeUrl=http://patft.uspto.gov/netacgi/nph-Parser?Sect1=PTO1%2526Sect2=HITOFF%2526d=PALL%2526p=1%2526u=%25252Fnetahtml%25252FPTO%25252Fsrchnum.htm%2526r=1%2526f=G%2526l=50%2
Mike L
FWIW, I've always seen the first brace called a corner brace and the second brace called a joist brace. Joist braces are more scarce in my experience. My corner brace hangs up high in my shop as a decoration with little need to be easily retrieved. One day I should at least test it just to see how well it works. My joist brace hasn't found its way to me yet......
