New WoodChat!
Sargent 410 hand plane
Bob
Bob
I have acquired a Sargent 410 hand plane. I restored it and it works fairly nice. I would like to obtain a thicker blade for better performance. I emailed Mr Hock, but he could not assure that one of his would fit.
Does anyone know where I can obtain a similar replacement? A2 or O steel is ok either way with me.
Bob
Re: Sargent 410 hand plane
Jim DeLaney, Austintown, Ohio
Your Sargent 410 is the equivalent of a Stanley 4½. If the iron is 2-3/8" wide, a Stanley iron ought to fit. I'm not sure whether the Sargent blade is 2-3/8" or 2-1/2" though, since I don't have an example here in front of me.
Bob
Bob
Its 2 3/8", I just measured. I have a LN low angle block - its the best plane I have but I don't have the wallet for the smoother.
If I get the stanley replacement blade from Hock do you think the stock chip breaker is ok? I am guessing yes. This should make this plane sing much better.
Thanks, Bob
Archie
Careful, now!
I've had to drill and cut new sockets for the Sargent adj mechanism to catch properly on the chipbreaker. My Stanley and Sargent chipbreakers have not played together well at all :), so be prepared to do some drilling and filing. I'm supposing that's what Ron Hock was hesitant about.
The metal on the two chipbreakers that I've re-cut were soft metal and not problems to measure and then cut. But, I had the original CB on the plane to work with.
If your Stanley parts fit the Sargent, congratulations! That's a great thing.
Bob
Bob
You are correct!. All measures the same EXCEPT the adjustment lever slot. it is 1/8" higher than the Stanley. Ron Hock has a good diagram of it on line. If it is soft I can see filing it up a bit. I measured an usable adjustment range of .35" to .4" along the blade axis. I am thinking this will still work. If not I may only have to work it 1/16" of an inch to get it to play, maybe not the entire 1/8".
Good catch!
I would rather have a LN, but if I can get a hock blade/chipper to work I should be satisfied.
Bob
Chuck Bjorgen
Just a thought, Bob, but why not either trace the outline and inner details onto a piece of paper and mail or email that to Ron Hock to see how close his cutter might be. An alternative would be to put the cutter on a copy machine and use the resulting copy.
Bob
Bob
Would it be so bad to reuse the original chip breaker with a new Hock blade? That may be my best compramise?
Bob
Archie
Unless there's a terrible problem with the original CB, I would urge you to use it. First, I too often have problems with the combination of a Hock blade + CB being too thick to fit a vintage plane throat. Second, though the newer CBs are much better, originals in good+ shape work just fine. YMMV.
