New WoodChat!
Fun with Kaizen Foam
Phil
Some of you may have seen the article in the recent edition of Fine Woodworking regarding a new product by Fastcap called Kaizen Foam. It is essentially a piece of packing foam that is made up of thin laminated sheets. For tool storage in drawers, you cut a piece to fit the inside of the drawer, and then you arrange the tools where you want them on the foam. You cut an outline of the tool in the foam with a utility or exacto knife, and you peel away any number of layers of laminated foam to allow the tool to sit in a custom recess. For anyone that stores their tools in drawers, this is a great product. I've done most of my measuring tools (see photo), and I'll be doing hand tool storage next.
Re: Fun with Kaizen Foam
Bruce, a MN Galoot
That looks downright interesting. It sure would teach those pesky critters to stay where you put them! Post when you get the hand tools finished. I'd like to see that.
Phil
I suppose this product is only interesting to someone who already stores tools in a drawer, and knows that they all migrate to a pile in the back of the drawer, even when you use some sort of drawer liner. I'll post the plane drawer when finished.
Phil
The finished marking/measuring drawer:
Guillaume Dery
I like the concept of this stuff and will investigate it some more in the near future (AKA when I am done building the damned shop). Just a general question though. Wouldn't it be more efficient and gain you a lot more room if your rulers were stored on edge rather than flat?
Bruce, a MN Galoot
I wondered about storing the rules vertically, too. I have this stuff in mind for a chest I'm designing, mostly for marking/measuring tools including micrometers and calipers. I also like the idea of preventing those things from sliding and bumping about. It sure would be a lot easier than french fitting that drawer. It would be less useful for many others, primarily because my tool set is constantly changing.
Phil
My tool set is pretty much fixed at this point (if I can't build Garrett Hack quality furniture with these tools, then its not the tools).
Hand plane drawer (took about an hour start to finish)
Phil
Sure, but I've got all the tools I need at this point, and if I fill up all the space now, I have a reason to stop collecting and spend more time building. Worst case, down the road, for what this foam costs, it can always be replaced to accommodate a new tool set.
Pam Niedermayer
This photo gives me pause. What's the "foam" made of? I'd be worried about moisture on the edges. But then, I don't store planes in drawers.
Pam
Phil
Not sure: it appears to be the same substance used for commercial/industrial packaging of heavy tools/equipment. 5 minutes of research on this stuff seems to indicate that it has been used for some indeterminate period of time in industry for tool storage, so I am assuming that its ok to use for cast iron/bronze tools (time will tell). If my planes start disintegrating, I will report back.
Thanks
Re: what is the red tool?
Phil
That is a Czeck Edge ruler stop: very nicely made and useful tool.
Re: thanks
Guillaume Dery
Their marking knives are fairly nice as well. They have a deeper reach than most and are spear points which I prefer
