New WoodChat!
inlay
inlay
inlay
eliotandmax
I'm really not sure the subject is 'inlay'. A friend asked me to make a small base for a sculpture. The base is just a square box about 5x5 inches and 3 inches high. But it required a square 3x3 recess about 1/8 deep set into the center of the top to accept the metal base of his sculpture. ( So I used the term. 'inlay', because I suppose one could set an inlay into this recess.)I did it with a small router. My question is,... how would this have been done before routers? Or, to put it differently, how would you do it today without using a router? He didn't want any seams or anything like that to show.
Re: inlay
Re: inlay
James Watriss
Carefully. :)
Chopping out waste is more or less easily done with a chisel. Bottom can be smoothed with a router plane. The perimeter is cut undersize and trimmed to fit.
Re: inlay
Re: inlay
eliotandmax
Thanks. Now that I'm thinking about it, what I have is just a shallow mortise. Still, it's that "smoothing -the bottom- with- a -router plane" that I don't quite get. wouldn't it have to be a very small plane to get in there?
Re: inlay
Re: inlay
Pam Niedermayer
For this type job, I use bent gouges and some regular chisels (bevel down for the control). Then, in your case, a small scraper could work to level the indentation, or, as James said, a router plane.
Pam
Re: inlay
Re: inlay
eliotandmax
Thanks for both replies. Would you, in fact, use hand tools for this job?The router did work well for me.
Re: inlay
Router planes *LINK*
Router planes differ from other planes in that the cutter hangs down below the body of the tool. In some ways, they're not really planes at all - more like chisels in a holder. The body of the plane bridges the opening, and the cutter hangs down into the opening to smooth it. If your opening is larger than the body of the plane, you can fasten a piece of wood or appropriate other material (plastic, aluminum, etc.) to it to extend its reach.
The link below is to one discussion of the larger of the two common router plane designs. If you go to the home page of this site, you can find the section that describes the No. 271, an example of the other common size.
These, and similar designs by Record (of England), Sargent, Millers-Falls, etc., are commonly available on the used market. Lee Valley and Lie-Nielsen, two makers of new hand tools, make their own designs (the image below is of Lee Valley's version); for some reason, the economy makers like WoodRiver have not yet come out with designs.
You can also make your own, if money is a consideration. For ideas, Google "old woman's tooth", the name of the traditional wooden version of this tool.
See the number 71, first plane described
Re: inlay
Re: inlay
Pam Niedermayer
Yes, I'd definitely use hand tools, chisels. It's only a 3" X 3" depression, probably very shallow, hardly worth the time to get the router out (honestly, I've never even used my electric router, and I'd be sorry I ever bought it except that the purchase made me eligible for a drawing for a big 12" compound miter saw, which I use all the time). I love doing this kind of chiseling job.
Pam
Re: inlay
One additional thought
Depending on the smoothness of the base of the sculpture, you might not have needed a recess with a level floor - indeed, in some cases, you're better off with a recess which is level only around its edges, but otherwise recessed, to accommodate any irregularities in the base of the object away from its edges. This could probably be more easily accomplished with hand tools (chisels, gouges) than with power tools.
This depends, of course, on the object in question. If the smooth part of the base is more toward the center, with the edges of the base being irregular, then you need good support in the middle.
Re: inlay
Re: inlay
TomD
You could make a router plane for that application by just screwing a screw into a board, the screw is adjustable for projection by just screwing it further in or out. Flat file the top of the screw or grind it, so that the edge of the screw is sharp. The head can be level, but it will also work if it is tipped a little, particularly for roughing. Once you have your basic excavation with the chisels, you use the "router plane" to make the base of the mortise level, and smooth, and free of most tool marks.
Using the chisel the key thing is how you go about the work relative to the grain. You need to outline the 3x3, then score across it for depth, cutting across the grain, bevel down. You need to find the right amount of force and bite. Trying to remove too little or too much, either can be a problem.
If you look at the part of this video that covers the hinges, you will see what kind of chiseling works.
http://video.pbs.org/video/2184224847
Re: inlay
Re: inlay
eliotandmax
Thanks. (You also answered a question I asked about sharpening with diamond stones.)
Since you say you love doing this kind of job with chisels, I have to assume that you are a tried and true hand tool woodworker. I did it with a small router because I didn't trust myself to get it flat all the way around with a chisel. It only took me a few minutes to tape down some strips of wood around the space and use a router bit with a bearing within the square, but I can see the satisfaction of doing it with hand tools. Perhaps next time I'll try it that way. Thanks again for your response.
