New WoodChat!
ADVERTISE HERE - FREE TRIAL
Cross Post
Cross Post
Cross Post
Lewis Dodd
I have a Grizzly cabinet saw and cannot figure out how to mount a sacrificial board to the miter---Any help out there?
Re: Cross Post
Moses Yoder
Re: Cross Post
Moses Yoder
Not sure what model saw you have or what the miter gauge looks like (i assume when you say miter you mean miter gauge) . On my Delta miter guage there were holes drilled through and I simply put screws through them to attach a board. On yours, you may have to drill holes through. Hand tool content; the holes should be drilled with a breast drill, and the board prepped entirely by hand. The screws are easily driven with a brace and bit.
Re: Cross Post
Alternative
Bill Tindall
Make a table saw sled (something that seems to be called a boat on the show Rough Cut whose name apparently refers to the quality of the edit). Sleds produce more precise cuts than any miter, stops of any sort can be rigged along the fence, they hold securely large pieces, etc. Every table saw should own one.
Re: Cross Post
Re: Cross Post
Lewis Dodd
Well, I called Grizzly this morning and heard what I expected, I gotta drill the holes myself, thanks for your help.
Re: Cross Post
Re: Alternative
Guillaume Dery
+1 for What Bill said.
Specially if they didn't put holes in your miter gauge (most manufacturer miter gauges are a POS, BTW).
Take a couple of hours in the shop and make a sled. You can outfit it to do miters as well as just crosscuts.
Re: Cross Post
Yep
roninkokomo
A well made sled will outperform and miter gauge.
I routed a semicircular slot through mine to allow for miter cuts of any angle.
Only way to go IMHO
Ron
