Re: Profiled griding wheel?
Mike Holden
Profiled grinding wheels are standard procedure for press shops. There are commercial jigs that shape the wheels available, but very expensive. In a normal progressive die there might be 5 to 20 wheels made up and kept in the toolshop for touching up details as they wear. The wheels would be saved and packaged up when a die is taken out of service for the inevitable service run of parts two, three years down the road.
Creep grinding is another use of profiled grinding wheels.
Shape your wheel to the dimensions you need, using it only for the final touch up. Dont plan on grinding it for any other shape though, you will get really small diameter really quickly.
Of course, this all depends on your point of view - in a stamping house, with $100,000 dies, and Die maintenance people costing $100/hr, dedicating 20 grinding wheels to a die makes economic sense. For a home workshop, not so much.
