Workbench progress
Stuart Hough
Well, finally, after almost three years, I am almost to the point of getting the FRW (First Real Workbench) together. Drilled and pared the mortices for the stretchers about two weeks ago. Had some time Wednesday to do a dry-fit on the base assembly. One tenon had to be "persuaded" into place, but everything looked square. Measured the diagonals today and NOT! Had a half-inch difference that I could not understand. After much pushing and prodding I got it close, but was not satisfied with leaving it that way. So I stood back, thought a bit, and took it apart. I figured out what was causing the one tenon to be too tight (actually the mortice had one wall that was tapered...fixed that), and thought...maybe if I swap some pieces around it'll work out. Swapped two diagonally opposite legs and the end stretchers for each other and "Lo and Behold!" it's square! Caveat is, that means something has moved since I milled the legs and stretchers to final dimension last year. The legs are not exactly square to each other on the ends, but I think I can adjust that before I glue it all together.
I know what you're thinking...three years...what's he been doing?!? I'm slow at this, but I do as I learn new things. I'm probably too careful about what I do on the millimg and fitting, because any screwups are costly. Also work demands far too much of my time. But my one and only resolution for this year is to take back my time, so I can enjoy doing (or worrying about doing) things , like this, for me...oh ! and of course for the LOML. I'll post more as I accomplish more, or need advice. Thanks to the Monday Night chat group for the encouragement and tips they provide...without which I wouldn't be this far along.
