Leg Vice
Philip Duffy
Bought me a nice old leg vise and am looking for an expert on these beauties. Seller told me it was 1870 era, but I have my doubts. Who's the expert on this subject that can tell me what to look for? Philip
Leg Vice
Philip Duffy
Iron or wood?
Re: Iron or wood?
Philip Duffy
Iron. So far, using the search modes of various sites I have learned that mine is not one of the famous English made ones but is looks like it is from the same era of about 1840-60. I will continue to look for markings that may give a clue as to point of origin. Phil
Re: Iron or wood?
Bob Hackett
Most of the iron ones are identified by maker`s marks on the screw box,the upper part of the leg or sometimes on the mounting bracket. If there are no markings the shape of the screw box and the mounting bracket can be a help in IDing it.
Any chance of a pic?
I've never understood the purpose
Gary Smyth
of the leg. I have onet that came with my old home, but never installed it because I didn't understand its full purpose. I too would like to see a picture if possible.
Re: I've never understood the purpose
Philip Duffy
Will try to post some pics today, if the rain stops.
The leg, as I understand it from a blacksmith who has one is for the bottom to rest on the floor of the shop and that allows heavy pounding on heated iron in the jaws.
Blacksmith's vise
Jack Guzman from Maine
I'm sorry that I can't help you with identification. A picture would be helpful.Besides flea markets,the only place I've ever seen those is in blacksmith's shops.I've never heard them called leg vises. To me,a leg vise is a horizontal wooden jaw that pivots on a leg and clamps to the top edge of a bench. I was at a yard sale a few years back and saw a blacksmith's vise laying on it's side on the seller's lawn. It was too pretty to pass up.Everything was intact, including the spring. I paid $25 for it and mounted it by the door to my shop. I mostly use it for hacksawing the occasional piece of metal or sharpening my chainsaw. It's handy in a shop. I drilled a hole in the wood floor(over concrete)and set the post in it and bolted the vise to a narrow bench against the wall.---Jack
What is this?
Gary Smyth
I’m not trying to hijack Phil's post but this is what I have. Is it a leg vise, a post vise (which is what I was told to call this one), blacksmith's vise or are they one in the same? I’ve seen large long tweezer type vises that are made of wood and attached to a bench but I've heard these were called a farrier's vise. I’ve not heard them called a leg vise. At least now I see why there is a ball on the bottom. It anchor's the tab extension when a smaller hole is set in the floor
Post,stump leg vise
I just googled the term post vise. According to ebay posters it is listed as post,leg,blacksmith,and/or stump vise. I guess it has been called all of the above terms. Maybe more? What do Blacksmiths call it?---Jack--seeking the ultimate truth in visedom
TomD
That's right about the purpose of the post. With most vises one is told not to beat on something in them. So one would not mortise a part held in the jaws, one would clamp that board to the top of the bench or possibly use dogs. So the post is unique in that respect.
I always think of a vise that uses one leg of the bench as part of one jaw as a Leg Vise. But that is just my crutch the terms seem interchangeable.
Re: stump vise
TomD
Stump vise or anvil, in my world refer to vises or anvils that have a spike that allows them to be mounted in a log for field expedient repairs. Even today they make these items in modern versions for chainsaw maintenance. Not sure what a stump anvil is for. It would be very handy for scythe maintenance. People with minimal smithing aspirations buy them as cheap anvils, but in older times that seems an unlikely use.
In my neck of the woods...
Bob Hackett
The vise in the pic is a post or leg vise.
They excel in metalworking for the reasons stated above. Take an 8-16 pound sledgehammer and beat on steel in a conventional vise attached to a bench and over time the vise,bench or both will be damaged if not destroyed. The leg transfers the force of the pounding directly to the ground just like a base for an anvil would. The destructive forces of heavy hammering are dissipated rather than absorbed by and damaging to the vise and whatever it`s attached to. The mounting bracket that allows you to bolt it to something is designed so the wedges that hold the vise to the bracket allow the body a certain amount of vertical movement/self adjustment and that also helps to isolate the pounding forces and transfer the forces thru the leg to the floor/ground. I have a thick steel backing plate with a hole drilled in it under the leg of mine.
Re: Leg Vice
Philip Duffy
C:\Users\PF Duffy\Pictures\Peter Whright leg vise\P1010182.JPG
Oh, by the bye, the spelling of his name is correct--from the vise itself. The decorative cover at the back of the fixed jaw is broken off and the handle a bit crooked but the jaws look great. Pleased as punch, as they say in New England. Phil
I don't have a 'warm and fuzzy' that the picture will show up here. Best I go read some help directions.
