Re: question for you bolster boys
TomD
The bolsters on most modern knives were not being hit with anything, which allows them to even be epoxied. Chisels are a different mater.
Many makers of knives that are designed to be used in combat, do not want their tangs welded. Welds can weaken the metal too much. What welding does and doesn't do is a pretty complex subject. For instance many of these same knives would have forge welded blades because they are argued to be more durable. But tangs are a different mater.
One way to go with modern steels is to make parts integral. Grinding removes material so quickly you can simply grind some of these features in. The easiest way to mount a really strong handle is to epoxy bond it. This is not just adding a dab of glue. You want to float the tang in a socket of epoxy. This is how one adds maximum strength load take-offs to wooden structures, when there isn't much space. It is also the easiest method.
At the other extreme, a lot of home made tools do not need to be ultimate in durability. Home made tools can be easily replaced or rebuilt. They are presumably to be used by non-thugs. Probably the user has some respect for them. Home made tools also are fast to make, and one can all of a sudden have a specialty tool for every use, so individual tools see less wear. One can lavish the really heavy construction on the odd tool that really needs it, without overbuilding every other tool. One doesn't have to give each tool the same construction so that it will match a set for marketing reasons.
